sp c250sf
  • Marwanalhajbi
    • Jul 2018
    • 72
    sp c250sf
    i have an issue with the wifi
    it only print when i turn it on,after 10 minute or more it doesn't get the order,i have to restart it to take the order,i have updated the firmware also it print just fine with LAN connection
    any suggestion?
  • HitMan
    • Aug 2015
    • 170
    Re: sp c250sf
    Maybe theres another device connecting to the ip address? Have you tried pinging the ip with the printer off?
    Sent from my SM-G930F using Tapatalk
    • aktasson
      • Feb 2017
      • 201
      Re: sp c250sf
      any suggestion?
      Ad hoc or infrastructure mode? Wifi environment and signal strength checked (with a smartphone and wifi hf analyzer) ?
      Eco or energy saver disabled? Wifi channel of repeater/access point changed (not in auto mode)?
      • copier tech
        • 8144
        Re: sp c250sf
        If it prints fine over LAN can you simply not use wifi?
