MPC401 Trapeziod problem
  • Hadster
    • Aug 2011
    • 264
    1st.= I set erase margins to 0 in order to see the edge of the paper better. 2nd= I know side to side is off but they are straight! Problem happens when using the RADF or laying on the glass. I see no adjustment in the MPC401 manual like other service manuals where you adjust the fuser guide for Trapezoid. This is a major problem with this customer (Lawyer) because when they scan the originals and send them to the court house they look crooked and thus refuse them. And, when they are scanned the problem is exaggerated making them barely legible.The example is from my machine in the shop which is far better than the customers BTW. Thanks for any insight!!!
    • 22997
    Re: MPC401 Trapeziod problem
    I suspect that the scanner frame may be bent, front leaning on the corner. Are internal prints and prints of electronic documents square? I suspect yes. =^..^=
    • mikadonovan
      • May 2008
      • 2931
      Since there is no CIS on this one, you might have a mirror out of position, or a scanner problem.
      NEVER ASSUME ANYTHING
      • Hadster
        • Aug 2011
        • 264
        Nevermind... Loosen the scanner screws on the side and moved it up 2mm. Problem solved. Thanks for your response!
          • 37351
          Now tell the users to stop leaning on the machine or the problem will come back.
          • Hadster
            • Aug 2011
            • 264
            I hear ya but machine is located in a corner and I don't think it was that THIS time.
            • fshead
              • 2360
              I always felt the adf hinges had way too much play and you can have it close in different locations depending
              where you put pressure closing it..
