Different between developer of type 21 and 24
  • windcopier
    • Apr 2019
    • 51
    Hi.
    Does everybody know between the ricoh developer type21 and 24?
    bcas i use both in same model like MP2075 MP7500 MP7502 also the same. The life spend also the same.
    thank you for the advice.
    • 37352
    Re: Different between developer of type 21 and 24
    EU vs NA
    • windcopier
      • Apr 2019
      • 51
      EU vs NA
      Because of different area right?
      thank you.
        • 37352
        thank you.
        We also found that there was a price difference so we always ordered which ever was less expensive.
        • windcopier
          • Apr 2019
          • 51
          thank you for your advice.
          • luca72
            • Oct 2017
            • 1742
            I noticed on precisionroller. that the most expensive (type21) contains 1250gr, against type 24 (900gr), what do you usually do, do you put less?
            "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
            • Butrus
              • Jan 2012
              • 115
              I noticed that too.But its wrong.
              Type24 has 900g and type21 has 1000g
              • Zaxxon
                • 608
                3
                Please start you post with brand, model, problem.
                • windcopier
                  • Apr 2019
                  • 51
                  Yes . type 21 is 1kg.
                  That is why im wonder any different between type 24 and type 21.
                  • Butrus
                    • Jan 2012
                    • 115
                    Yes.
                    100g
                    Never found it an issue.
