ricoh customer engineer tool
  • dalewb74
    • Feb 2018
    • 1167
    this is a new tool from ricoh. has anyone had a chance to use it yet? if you have, how well does it work?
    rfg081037 is a demo of the tool. looks very promising if it works as described.
    • 37653
    Re: ricoh customer engineer tool
    rfg08059 is a bulletin is announcing the release of the Customer Engineer Tool. It includes a table of the following supported models
    MP C2004/C2504/C3004/C3504/C4504/C5504/C6004
    MP C2004ex/C2504ex/C3004ex/C3504ex/C4504ex/C5504ex/C6004ex
    IM C2000/C2500/C3000/C3500/C4500/C5500/C6000
    and the required firmware for each model.
    • dalewb74
      • Feb 2018
      • 1167
      yeah i have the info. but wondering has anyone used it yet? and how well it works? i am about to do my first stall of the APP on a test machine at the office. just looking for feedback on if it's any good or not? if anyone has had issues. it sounds really good in theory, but you know.
      • DRichard
        • May 2008
        • 482
        We have been installing the app on all applicable models since Ricoh made it available. It seems as though it will be very useful and efficient as it becomes necessary for our field techs to trouble shoot with. It is basically a graphical interface to access many of the service mode tools already present, but in a much more "at your fingertips" way of finding which tools you would like to use. There are a couple more nice features too. Definitely recommend loading it up and practicing with it.
        "Enjoy every sandwich."
        -- Warren Zevon
        • dalewb74
          • Feb 2018
          • 1167
          yeah i installed it on my first machine. and have kinda navigated around a bit looking at everything. looks like it will be very handy for us techs to use out in the field. i especially like the option where you can see the motors and turn those on or off. plus how it shows the locations of the paper jams and how many have occurred in that spot.
          • Codex
            • May 2008
            • 705
            Hello
            Can someone post the rfg08059 here?.i cant find it on Ricoh Italy, only Remote Support tool or remote assistant.
            Thank you
            Memento Audere Semper
            • paulg
              • Jun 2007
              • 278
              Originally posted by Codex
              Hello
              Thank you
              I think that is a American bulletin so us Europeans will not normally see on My ricoh.com
              RUK helpdesk told us the File can be found here they did supply a PDF at the time but the information on how to use and what it CESA is. Is all in the new IMC Service manual to use CESA. https://www.my-ricoh.com/Portal/Publ...c49#DetailsTab
              Locally we have been advised to make sure you get the customers permission to have on the device and be careful where if at all its permanently installed on a MFP. As the Password, well I won't type it on here but once it is know means the end user can access.
              • FrohnB
                • Jul 2017
                • 1919
                If you're having trouble finding the tool:
                Go to the IM C2000 firmware download page, it's under "custom firmware", Download it, and put the "app" folder with the zipped contents on the root of SD card, insert card into slot on screen, go into panel service mode --> Apps --> Install from SD card (takes about thirty seconds). Then you can play around with it, that's what I had to do, could find limited info on it.
                Omertà
                • dalewb74
                  • Feb 2018
                  • 1167
                  word of advice make sure your firmware is up-to-date. and that the model you are installing on is in the compatibility list. we are gonna just install it on all of our machines before we take to the customer. as far as customer access, you can't access what i don't get you the password for.... personally i don't think a customer needs to mess with that. that should be for techs. no idea why they even named it customer, it should have been tech. engineer tool. but just playing around with it a bit in house seems like a really good troubleshooter to use. that fact it shows a diagram of the copier and where all jams are located and how many have occurred in that area. plus i can look at voltage and fuser temp. plus i can turn on and off motors and such to see if they are operational is nice. i was working with it to get more familiar and was even able to turn the scan lamp on and off. i just hope that whenever a real issue occurs i will still be able to access the app. on screen. hmmmmm seems i have said some of these things already, but yeah nice app for troubleshooting.
                  • paulg
                    • Jun 2007
                    • 278
                    Its a step forward but unless it has been updated recently the fact you can't change the password. Well with out changing other passwords, for me is a concern. I haven't noticed much the nosey Customer can do which will cause harm or chaos in the app but rest assured somewhere out there is a customer or two who has the capability
                    The checking with the Customer, I think was to make sure they didn't ring up and ask what this app they could not use was.
                    • DRichard
                      • May 2008
                      • 482
                      Originally posted by paulg
                      ...rest assured somewhere out there is a customer or two who has the capability
                      OH, So True...
                      -- Warren Zevon
                      • JayPaul
                        • Oct 2012
                        • 305
                        I finally got a moment to load this up on a 4504 earlier and I quite like it, password protected which in theory only Ricoh techs should be able to access it until some idiot blabs it out loud and in a few years lots of nosey people will know how to use it. The fact it can show jam locations and amounts in picture format is so much quicker than checking logs against code numbers (I am useless at remembering jam code locations). I think the output mode feature is good but it needs a bit more work, it's slightly fiddly zooming in to certain areas without accidentally pressing one of them.
                        A really good tool to show new techs though as I'll be taking on a trainee in the coming months I will show him how easy it is to find jam locations etc.
                        I would say as well either put it on the 3rd page along so customers are less likely to find it, or even just don't put it on any home screens and go into the widgets/apps bit, and do it that way, deleting it afterwards. It is definitely not for customers at all, they could really f*ck something up pressing random outputs motors on dev units and such.
                        Worth having a go if you have a spare 20 mins to load up firmware and searching through the app
                        It gets a thumbs up from me
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          One other thing we've been doing to avoid this is bury the icon in a place that they can't find it OR just leave the App icon in the Applications section.
                          • Codex
                            • May 2008
                            • 705
                            hy
                            i installed the tool on a MP3504, but the app starts in Japanese, i tried to play with it using google lens to find language options, but i found nothing......how can i swith the language in this app??
                            • Zeldaman
                              • Mar 2011
                              • 946
                              Hi there!
                              Codex, you must use the change-language-button & switch to english, then the tool is in english too. There are only japanese & english language availible (until now).
                              Greetings...
