MP 3054 firmware
  • wester
    • Aug 2009
    • 113
    MP 3054 firmware
    Would someone have the latest firmware numbers(versions)? The firmware history would be nice. Just want to see if my printing problems are related to the firmware. Thanks in advance.
    • 37478
    Re: MP 3054 firmware
    Why not tell us what your printing problems are so we can diagnose your problem? Hate to see you wait days for firmware when the actual problem could be solved in hours.
    • wester
      • Aug 2009
      • 113
      At a doctors office, just certain documents from "Allscript" seem to get hung up, ie. out of a 6 page document the firstn3 pages come out quickly, then "stalls" out, says processing then after up to 5min the other pages will print. They have a MP 6002 in same office if they send there everything is fine. I hope I explained ok. The same thing was happening with their previous MP 3351.
      • tufbnme
        • 493
        FW History MP3054.pdf
        • sandmanmac
          • 3981
          Printer installed on the infamous WSD port rather than TCP/IP?
            • 37478
            Originally posted by sandmanmac
            Printing installed on the infamous WSD port rather than TCP/IP?
            May also be using Microsoft's notorious Ricoh class driver.
            • skinnyb
              • Jul 2008
              • 291
              Bingo
              Sent from my LM-V405 using Tapatalk
              • skinnyb
                • Jul 2008
                • 291
                Bingo x2
                • wester
                  • Aug 2009
                  • 113
                  Thanks, I'm meeting with their IT guy there later this morning and will let you know.
                  • wester
                    • Aug 2009
                    • 113
                    Well that didn't work. He had PCL 6 universal in, we changed to PCL 6, no go, then 5e still same. He put PCL 6 universal back in. Its only on the one document (preg. report) from Allscript and usually on page 4 when it starts. This is a toughy. It started when they went to "the cloud" with Alscript.
                      • 37478
                      Are they pooling multiple devices of different make and/or model? That is the purpose of the universal driver.
                      • copier tech
                        • 8142
                        Your inbox is full, delete your read messages so we can PM you.
                        • wester
                          • Aug 2009
                          • 113
                          done
                          • guitar9199
                            • Sep 2016
                            • 1100
                            Sounds like the problem is with Allscript. If it's generating a PDF for printing, try clicking on the PDF reader print settings under Advanced, and check "Print as Image", and see if that makes a difference.
                            • copier tech
                              • 8142
                              done
                              Try again still says full!
