Mpc 4500 color registration problem
  • Wishbone
    • 100
    B/W looks fine. None of the colors line up and it won't even pass the rough adjustment in service mode. I replaced the whole transfer unit and cleaned the id sensors and didn't help, still won't pass. Firmware was also updated to the latest and greatest. Any other idea's?
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Haven't had the colour registration problem but the manual says a few things to try:
    Color Registration
    displayed at the end. Also, you can check the result with SP 2-194-10 to -12.
    also try the normall ACC or sp 3001-004 (full music) after cleaning the sensors.
    Incontinentia Buttocks
    • Wishbone
      • 100
      Yes have tried that. SP2-111-3 is the rough adjustment. New Id sensors will be in today. Also the color dev units have 180,000 on them which are overdue. I will replace the dev as maybe the patch isn't good enough to get a good registration reading. If all this fails today then I will look at NVram.
      • Jomama46
        • 2900
        There is a long-ass but effective procedure written for the DSc445s (#32) that has been effective for me. It requires a loupe in order to see the lines but if you have replaced the transfer belt and cleaned the top roller, this is the next step.
        sigpic
        A+; Network +; PDI+
        • tjvincent
          • 280
          Are all 3 of your colors toned up , if not try toning up manually first , I have seen this a few times cause your line adjust to fail.
          • Wishbone
            • 100
            Just to update I got this problem resolved today. I replaced the developer and that fixed it right away. I replace all 4 of them but imo the black one was worse off than the colors. It uses black even in full color mode and it was really week causing a poor patch that could not be read. Easy fix thank goodness and I'll file it away in my head for another day!
            • Jomama46
              • 2900
              Glad you got it sorted out without pulling all your hair out.
              sigpic
              A+; Network +; PDI+
