MP 8000 can not printed.
  • NexusTech
    • Apr 2019
    • 10
    [Misc] MP 8000 can not printed.
    Hello, my machine will not print at all. I have used the other device SD card with the print scan and it is not working again. Does anyone know how to insert the firmware into the machine. I have a book of mp7500 but unsuccessfully. What card is going to boot the firmware i have 2gbSD card but will not boot.
  • davel
    • Oct 2011
    • 1104
    Re: MP 8000 can not printed.
    Sounds like you are not a tech, if machine has no print/scan DF card it will not work. If you mix up firmware loading you can kill the machine. Call in a trained tech.
    • NexusTech
      • Apr 2019
      • 10
      Yes im tech.I have an original firmware but i have never worked on this series...
        • 37494
        By tech we mean a trained and qualified Ricoh tech. If you were such, you would know how to load firmware updates. As davel said, if the machine does not have a print/scan SD card, it will not print. Print/Scan SD card is not a firmware update. It is an option that you have to purchase and install.
        • NexusTech
          • Apr 2019
          • 10
          Ok i buy 2x MP8000 and 8001 in Germany and 8001 its OK for MP8000 i have print/scaner kit type8000 with SD card and put in option slot with 2 DimmRAM 2x256MB
          • keithxxiii
            Just a tech
            • Nov 2014
            • 469
            Firmware update procedure is included in the manual.
            You should obtain a copy of the service manual.
            Hire a qualified ricoh tech and maybe, you will learn from him how to deal with this problem.
            Aye! Cut the crap
            • davel
              • Oct 2011
              • 1104
              Print/scan card goes in slot 1(top)
              • NeoMatrix
                Senior Tech.
                • 3513
                From memory...
                I believe the size of the 2GB SD card might not read on some of the older model Ricoh machines.
                Try a smaller SD card, say 512Mb, and format it to FAT32.
                Reinstall all the firmware onto the 512Mb SD card, and try the F/W update again.
                HTH
                  • 37494
                  From memory...
                  HTH
                  For some reason, most older models will not recognize an SD card formatted using Microsoft Windows format utility. Ricoh recommends that when you format an SD card, use the Panasonic SD card format utility. The following link is from TSRC Utilities. It does not mention Windows 8, 8.1 and 10 because the page was written before they came out. SD/SDHC/SDXC Memory Card Download | SD Memory Card | Digital AV | Support | Panasonic Global
                  Another option is MiniTool Partition Wizard. It not only does a good job of formatting but also allows you to create a 1GB or 512MB SD card from a larger card. Handy when you have an older model that will not accept 2GB or larger cards.
                  • NexusTech
                    • Apr 2019
                    • 10
                    OK im done all thes and room folder on 512MB SD card but machine not boothing this sd card i dont know why.I buy orginal firmware from Ricoh dealer but machine is not buthing from card.I put SD card i c3 service slot with 2 more card on c1 softver c2 print/scan c3 this firmwere.Machine working only print not working any idea for that....
                    • NexusTech
                      • Apr 2019
                      • 10
                      Txnx guys problem solved....in web browser network setup and port LPR and DIprint has ben desabled click enable then machine update now is working.....
