Ricoh SP4210 (Lanier LP 37N) printing from iphone ?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4535
    Is there a way to print from iphone to this older Lanier model ? It is connected with USB to a workstation, and the workstation in on their wired / wireless network. The printer is shared and PC always left on.
    Maybe a wireless adapter if Ricoh offered such a thing?
    They said the printer does not show on their Iphones like the printer I replaced. The printer I replaced was a small wireless throw away POS!
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: Ricoh SP4210 (Lanier LP 37N) printing from iphone ?
    In addition to printer USB cable to PC:
    You should be able to plug the printer directly into LAN Ethernet switch or router and install a LAN printer driver on the share PC.
    Assuming the LAN is WIFI capable:
    Is the iPhone on the same active network or subnet as the LAN PC?
    Is the LAN PC firewall set to Public or Private network settings?
    Can the share PC see the iPhone on the LAN?
    I'm unsure if the SP4210 is capable of direct AirPrint. It is capable of WiFi networking.
    Search Apple Store for any free network iPhone printer Apps that will interface via WiFi into the LAN.
    Install the free App to the iPhone and test the connection to the printer or the shared PC on the LAN.
    HTH
    • copyman
      Owner / Technician
      • Sep 2005
      • 4535
      Thanks for the great detailed info. Will give it a shot.
      • davel
        • Oct 2011
        • 1079
        Use Ricoh connector app network the printer and it should work,I have an old AP410 at home that works.
