Re: Ricoh aficio mp 2851 user auth error / no privilegies as admin help request
Well I didn't knew that the computer login has to be a must have. That's a step that I would do later. But right now what I mean, it's the copier login interface, the one you enter in the copier itself. Not in the scan folder set up, but in the copier I mean, top right corner, login button, when you touch it (or using the login button they the copier has) that is the thing I don't get to work. The login authentication on the copier, not in the shared folder thing.
Like when you login as admin in the copier, well, I can not login as user after having correctly created one.
