2232C transfer unit bound up
  • tinfox
    • 317
    When the machine is initializing it makes a grinding noise. It looks like its from the transfer unit. I have tried to rotate the gears by hand an it feels really hard to turn. Is there something I can lube or something I can do to loosen it up.
    The transfer unit is so integrated I am hoping someone has run into this before and can point me in the right direction so I don't have to disassemble the whole thing.
    TIA
  • Jomama46
    • 2900
    It may be the cleaning blade is causing friction on the belt. Cleaning unit is on the upper left and there is a handle on the bottom that you can press to release the blade. The blade is available separately.
    sigpic
    A+; Network +; PDI+
    • Polo-022
      • Sep 2007
      • 486
      Check transfer belt cleaning brush also, if it turns without friction. Bushings can stuck. Replace the unit for sure, if it is over the yield.
