Proper way to uninstall JAVA?
  • fshead
    • 2378
    HI
    I picked up a mpc3503 with Java and it takes for ever to come to start up ready screen.
    Can I just uninstall it?
    thanks
  • zed255
    How'd ya manage that?
    • 1020
    Re: Proper way to uninstall JAVA?
    The MPCxx03 series have Java installed on a flash ROM on the controller. You can use SP5-730-1 set to '0' to disable Java. The manual says input a Java license code there to enable, but I have never seen it set for anything but either a 1 or a 0. When set to 0 java definitely does not run, and yes the machine feels more responsive.
    • fshead
      • 2378
      thanks
      i gotta ck if that is the one i set to 0 along with the 20day setting too.
      • Kimi
        • Feb 2018
        • 105
        check that function priority is not set to java as well.
        • fshead
          • 2378
          thanks all.
          i was able to uninstall java and had java turned off b4 doing it via sp5730-1 but machine is slow to come to ready..
          I d say it takes 3-4 minutes....
          i formatted HD via service mode and this machine originally had "Equitrac" installed and
          user codes...
            • 8275
            Originally posted by fshead
            thanks all.
            user codes...
            3-4 minutes to boot up is a long time.
            What v firmware is the machine on?
            โ€‹
            • fshead
              • 2378
              it has the latest package FW and system was 1.31 and doing the FW did nothing.
              So i pulled the hard drive and swapped another good pull and it came up right away wth format HD..
              Now i am thinking that might be it.
              I let it finish and re power up,and same 3-4 minute wait for normal screen.
              So i go into user tools and do the # system at the time and reset all the copiers functions back to factory default.
              I think only two of them reset,no printer,scanner,address book features would respond.
              Repower machine and went to normal screen in 20 seconds.nice
              • sandmanmac
                • 3992
                thanks all.
                user codes...
                Hey Andy.
                I just thought I'd chime in my my own 2 cents.
                I was contacted early last week by a colleague of mine to help out with similar (sounding) issue on an MP C300 at one of his client's. He's just a repair guy and doesn't know anything about IT or Networking. He apparently had someone else without much Ricoh experience try a bunch of stuff without any success.
                The original call was for very slow printing. I checked all of the usual things first: drivers, switches, cables, and of course that it wasn't using WSD port, etc. All Good.
                Only when I rebooted did I realize that it took forever to boot up, so I immediately figured JAVA was the culprit. It was installed, and they had absolutely no use for it, so I went about uninstalling. That made no difference to the boot speed. My next step was doing a memory clear on virtually everything - except Engine of course. They only use it for printing so that made my life a little easier. Rebooted, and it came to ready very quickly, and no slow printing issues after that.
                I wish I knew which module was the actual culprit.
                Go Raptors!!
                • fshead
                  • 2378
                  Whats up brother..are you ready for tonights game?
                  This machine was odd as it had EQUITRAC and would try to boot to a server originally which it couldnt find.
                  I was glad that after swapping out HD,FW update and uninstalling java I was able to get it normal.
                  I did some sp 5801 reset excluding 01 and 02 and it made no difference.
                  The change came in user tools..
                  GO RAPTORS.................
                  • sandmanmac
                    • 3992
                    Haha......yes I am!
                    Hoping for an historic night for our city and the league!!
                    • fshead
                      • 2378
                      does DURANT PLAY>???
                      • sandmanmac
                        • 3992
                        Oh yeah. Bring him on
                        • fshead
                          • 2378
                          be careful what you ask for................
                          He can be a game changer.........
