MP C6004 SC720-82
  • Ricoh-ono
    • 338
    MP C6004 SC720-82
    Sc 720-82
    Symptom: Finisher makes a "stuttering" sound. Machine throws an SC720-82.
    Cause: At the finisher exit. The mylars on top of the Guide:Leading Edge (D6884197) peel away and prevent the guide from moving in and out.
    Fix: My fix has been to cut off the damaged section and in some cases remove the mylar completely.
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
  • GIUBOSS
    • 1433
    Re: MP C6004 SC720-82
    quick and painless repair
    • Mr. Linde
      • Oct 2019
      • 1
      Great! Thanks a lot!
      • rhopp
        • Apr 2020
        • 1
        Originally posted by Ricoh-ono
        Sc 720-82
        [ATTACH=CONFIG]42702[/ATTACH]
        [ATTACH=CONFIG]42703[/ATTACH]
        • BAstro
          • Mar 2021
          • 1
          Apologies for reviving this thread, but thanks a million for the fix! I was about to rip the damn thing apart! This worked for a booklet finisher on an MP 5055
          • cjd10
            • May 2021
            • 1
            Same Here. MP 6503 Finisher. Don't think I even realized those things were in there until I ran across this thread.
            • citeog3
              • Jan 2013
              • 11
              You Sir have saved me a lot of pain. I removed the mylar and it indeed was bent upwards. Thank you.
              Sc 720-82
              • Kiatagi
                • Jun 2018
                • 8
                Sc 720-82
                thanks a lot for this solution
                • drew007
                  • May 2018
                  • 21
                  Absolute legend ! I should have looked here before ripping the finisher apart. 😂
