MP C4503 Ghosting
  • iscott
    • Mar 2010
    • 344
    MP C4503 Ghosting
    MP C4503 Ghosting only happens with black toner. Card Stock paper The fuser temp is turned all the way up. It was working on thick 3 but now you have to use thick 4 to keep it from happening. Afraid soon thick 4 won't work. We have ordered a new developer box for a separate image quality issue and this may take care of it. Using OEM toner. Any thoughts?
  • JayPaul
    • Oct 2012
    • 305
    Re: MP C4503 Ghosting
    What is the life of the fuser? I have noticed over the years new fusers can easily fuse toner onto say 120gsm paper on the plain paper setting but over time it starts to ghost and you change is to middle thick, then thick...
    Obviously the correct thing to do is set it as correct paper thickness on installation so that doesn't happen but they perform really well new then just progressively get worse nearer the end of its life.
    • davel
      • Oct 2011
      • 1107
      If only on black you may need PCU as well as dev unit.If they do lots of cardstock it will reduce the yield of the fuser.
      • iscott
        • Mar 2010
        • 344
        Fuser has 265K on it.
        • Reed
          • Feb 2011
          • 258
          I had a similar problem on one of these machines when the customer was using thick paper. It ended up being the fuser. Make sure you use all OEM parts. The girl in our office accidently got some aftermarket parts when the fuser needed to be rebuilt. After replacing the parts that is when the machine started having issues.
          • copier tech
            • 8174
            So its over PM life. There's your answer.
            • Kingnote
              • May 2019
              • 6
              Maybe the fuser! Check for wear there or melted plastic
              • JayPaul
                • Oct 2012
                • 305
                CopierTech: Isn't the life of a fuser 400k on the MPC4503 range, because it has the setting for replace fuser unit at 415k and stops working at 430k?
                Saying that I still think it is fuser any way because 265k is high enough that it is no longer at peak performance and so won't fuser unless a high thickness is set
                • copier tech
                  • 8174
                  • eddy out
                    • Oct 2016
                    • 359
                    My PSG says 400k is the expected life
                      • 37532
                      That would be for the K PCU. 600K for the K development unit. 270K for color PCU and development unit.
                      Fusing and PTR are 400K.
                      ITB unit is 600K
                      ITB cleaning is 300K
                      • paulg
                        • Jun 2007
                        • 278
                        400k is probably for 80g paper with fairly low coverage with in a certain time frame with the fusing temperature set to default. How long the runs were how often the device was warmed up to ready (even if no prints made)
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          Fuser sleeve wear is always dependent from which paper customer is using, like thickness and quality.
                          Moisture is always an (negative) issue.
