Ricoh software step to repeat in ricoh black and white production printers
  • Sahil102
    • Sep 2016
    • 26
    Hi
    Does anyone know about the software step to repeat given in Ricoh black and white production printers which lets you set 4 A4 size pages on single A3 sheet back to back. If anyone knows please help.
  • HitMan
    • Aug 2015
    • 170
    Re: Ricoh software step to repeat in ricoh black and white production printers
    In copy mode its called combine
    Sent from my SM-G930F using Tapatalk
    • Sahil102
      • Sep 2016
      • 26
      What does it exactly do buddy? Can you please little bit elaborate.
      Can you please give me the exact name for it.
      • HitMan
        • Aug 2015
        • 170
        Here's a picture
        • Sahil102
          • Sep 2016
          • 26
          Here's a picture
          What its called when we give printouts instead of photocopying.
          • HitMan
            • Aug 2015
            • 170
            Printing [emoji23][emoji106]
            • sandmanmac
              • 3981
              Really??!!
              Are you not prepared to try anything for yourself?
              Depending on the driver in use, it's under "layout" and you can select "xx pages per sheet" OR there could be an icon to select the feature.
              Wherever it is, it's not rocket science!
              • Sahil102
                • Sep 2016
                • 26
                Originally posted by sandmanmac
                Really??!!
                Hi sir
                I was planning to buy a ricoh black and white production printer
                ,came to know about this software called steptorepeat . I was looking for a feature suppose i have 2 A4 sheets back to back filled if i want 100 copies of it on a3 such that if cut a3 sheet from middle it gives me two sets .
                Is it possible
                • sandmanmac
                  • 3981
                  Hi sir
                  Is it possible
                  Unless I'm completely misunderstanding you, and I don't think that I am......what you're asking here is possible with virtually every printer, without the need for any 'special software'.
                  For example....I took a 2 page PDF (attached) and simply printed 2 pages on one using (FREE) Foxit PDF printer, but I could have output it to any of my printers in the same way, without the need to 'convert' the document first
                  sample.pdf
                  2 page - converted.pdf
                  • Sahil102
                    • Sep 2016
                    • 26
                    [ATTACH]42733[/ATTACH]
                    [ATTACH]42734[/ATTACH]
                    Hi
                    I want these two pages to be printed on A3 size such that 1st page comes on the front side of the a3 sheet and 2 nd page comes on the back side of the a3 sheet back of page 1 so that if i cut my a3 sheet into half i get two set of your file from single A3 sheet.
                    • sandmanmac
                      • 3981
                      Hi
                      I feel like we're going around in circles and my head hurts now.
                      Sorry...I'm out.
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        • Sahil102
                          • Sep 2016
                          • 26
                          What does step and repeat do anyone please help?
                            • 37533
                            If you are printing, it is usually done through the software you are using. As an example, with .pdf files in Acrobat reader you select File - Print, under Page Handling change Page Scaling to Multiple Pages per Sheet and set Pages per sheet and Page Order as you wish. A little trial and error might be necessary.
                            Or better yet, ask you receptionist how as she most likely knows more about printing options as you do.
                            • ricmartinho
                              • 142
                              The only thing I know that has something like "Step and Repeat", is a Fiery Server with the Impose option.
