Ricoh software step to repeat in ricoh black and white production printers
  • Sahil102
    • Sep 2016
    • 26
    #16
    Re: Ricoh software step to repeat in ricoh black and white production printers
    If you are printing, it is usually done through the software you are using. As an example, with .pdf files in Acrobat reader you select File - Print, under Page Handling change Page Scaling to Multiple Pages per Sheet and set Pages per sheet and Page Order as you wish. A little trial and error might be necessary.
    Or better yet, ask you receptionist how as she most likely knows more about printing options as you do.
    Hi
    Does fiery work for microsoft word file and pdf or all file types.
    • ricmartinho
      • 142
      #17
      "Step and Repeat" is also called "Gang Up Repeat".
      I think this is what you want to do: YouTube
      This a Fiery Server
      EFI Fiery Digital Print Servers | Ricoh USA
        • 37059
        #18
        Originally posted by ricmartinho
        The only thing I know that has something like "Step and Repeat", is a Fiery Server with the Impose option.
        I do not think that you full understand what the original poster is looking for. Software step to repeat is not "Step and Repeat" and merely requires understanding how to use features already within most software and print drivers.
          • 37059
          #19
          Originally posted by Sahil102
          Hi
          I do believe that you replied with quote to the wrong post.
          That said, to answer you question, Fiery works with print jobs not file types.
          • ricmartinho
            • 142
            #20
            Hi
            I want these two pages to be printed on A3 size such that 1st page comes on the front side of the a3 sheet and 2 nd page comes on the back side of the a3 sheet back of page 1 so that if i cut my a3 sheet into half i get two set of your file from single A3 sheet.
