Toner (powder) Compatibility - Ricoh C5200 vs Ricoh MP C6502
  • freejojoey
    • Jun 2019
    • 2
    Forum Newbie - I searched with a few different keywords and couldn't find a discussion about this other than someone suggesting to "look for formula codes on packaging".
    I accidentally purchased Magenta for C5200 instead of for C6502. I called Ricoh and they just tried to sell me the correct bottle. When I asked "is the powder inside the bottles compatible" the tech on the phone completely ignored the question, like she was afraid to answer it. I understand why she did that, perhaps to keep her job.
    I read on a similar forum post about "formula codes" and the original poster of that question was never able to find the formula codes on their packaging.
    Can anyone tell me if since the C5200 and the C6502 are so similar (and close in age) that the powder inside the bottles is compatible? I know the 6502 toner is compatible with other machines (the bottle that is), but I'm hoping to save time by just pouring the 5200 toner into the empty 6502 bottle. I always purchase OEM toner BTW.
    • 29576
    Re: Toner (powder) Compatibility - Ricoh C5200 vs Ricoh MP C6502
    Toner formula most likely is NOT same as each model is usually different in particle size do to developer unit , speed of copier and fuser temp.
    You will NEVER get an answer from Ricoh or any other copier company as its a
    proprietary trade secret
      • 37044
      The Pro C5200 and the MP C6502 are not the same engine and most likely are not the same toner/developer formulation.
      The Pro C5200 is the production version of the MP C6303/C8003, not the MP C6502. Production version of the MP C6502 is the Pro C5100S.
      • freejojoey
        • Jun 2019
        • 2
        Thank you bsm2 and slimslob ...looks like I have to go thru the refund process with ebay
          • 37044
          Ouch.
          • anothertech
            • 1757
            Better safe than sorry.
