SP4210 Disable Sensor
  • gaud1n
    • Mar 2019
    • 4
    [Misc] SP4210 Disable Sensor
    Hi,
    i have a special request:
    I want to disable the Paper Exit Sensor. The Printer is inside a carbinet, rear cover is open - so the paper can "fall out" the rear of the printer.
    I checked every sp twice...but cant find anything.
    Ideas....anyone?
  • davel
    • Oct 2011
    • 1094
    • The_man
      • Jan 2016
      • 40
      Re: SP4210 Disable Sensor
      Originally posted by gaud1n
      Hi,
      Ideas....anyone?
      Would doubt you can overide exit switch for safety purposes as close to fuser etc. move the device
      • gaud1n
        • Mar 2019
        • 4
        yeah... know what you mean. But i cant move the device.
        The carbinet is to protect the printer from dust. Its inside the baggage handling of an airport.
        There is atm a hp device...works like written above.
        • The_man
          • Jan 2016
          • 40
          Well if it works with rear door open I would say that door switch must be shorted or something, As far as getting the paper to exit that way you would have to come with a way of triggering the exit switch as it leaves the fuser but as previous post says paper must eject horizontaly out of fuser.
          You would need a curved tray after exit to push paper back round to rear. Why can't they just accept the way it comes out anyway!!!!!!!
          • davel
            • Oct 2011
            • 1094
            Surely there is a door in the cabinet to open so they can get prints, load paper, toner. You also need rear door closed to actuate safety switches. These printers handle dust ok, I have a number of SP4310's in little rooms off aircraft gates, dust causes no issues. The overactive users however keep breaking parts.
            PS is not the 4210 a bit too old for the job.
            • gaud1n
              • Mar 2019
              • 4
              why the easy way? there is always a hard way.
              Inside the carbinet is da hole...it fits with to the hp printer.... the paper exit the fuser inside the hole.
                • 37328
                What is a carbinet? If you mean cabinet, your local fire marshal might not approve.
                • gaud1n
                  • Mar 2019
                  • 4
                  This is no problem. Focus on the question...
                    • 37328
                    The answer to the question is NO.
