Ricoh MP C300 Duplex Paper Guide (Above Fuser on Door) Broke, Won't duplex
  • Doug James
    • Jan 2012
    • 935
    [Jamming] Ricoh MP C300 Duplex Paper Guide (Above Fuser on Door) Broke, Won't duplex
    The paper guide that moves to guide the paper through the duplex initially when coming out of the fuser. The plastic has broke on the rear end that holds and will not stay put. Seems this would be a common problem since the heat from the fuser probably caused it to deteriorate. I attached a pic of the front end (The rear was hard to get a pic where it was broke) Any help would be very appreciated Thanks !!!
    • 36866
    Re: Ricoh MP C300 Duplex Paper Guide (Above Fuser on Door) Broke, Won't duplex
    Most likely caused by someone leaning on it while removing a jam. Replace the base portion of the unit. You will have to take the gates, rollers and associated bushings and springs off the old unit.
    • Doug James
      • Jan 2012
      • 935
      Thanks so much !!! Really appreciate your help !!
      • sandmanmac
        • 3964
        So far I guess I've been lucky, because I haven't seen this issue myself, but I remembered a thread from some time ago with a link to Ebay for a repair kit for this issue, and I found the thread.
        I'm by no means promoting it as I've not seen or tried it myself, but it might be of some help to you to have look at it and build your own 'fix' and maybe even give it a try.
        Good luck!
        Repair Kit Duplex for RICOH MPC300/400/401 | eBay
        • fshead
          • 2356
          I see if you dont lock down the fuser lock lever on each side the side door will not close.
          I have made my own repair as it was time wise to do so.
          I traced out the side pice from the opposite side and cut out the pattern with an old credit card,made the cutout to lock the
          piece and attached using 5 min epoxy being careful it does not get near the moving part.
          • Doug James
            • Jan 2012
            • 935
            You guys know what part to get, my guess was 111.M0264561. I've looked at the parts diagram for what seems like hours trying to figure it out. Thanks so much !!! I attached the parts diagram.... (Is is just me or are Ricoh's parts diagrams a little screwy)
            • FrohnB
              • Jul 2017
              • 1919
              Picture shows what I'm assuming is broken.?
              If it is indeed that guide, then you have the correct part number.
              Omertà
              • FrohnB
                • Jul 2017
                • 1919
                Otherwise, what we usually see is the "pawl gate" that's just above the last guide I posted gets broken on front or rear.
                First picture shows where it usually breaks on rear. Second picture shows the guide out of place (The front side is broken where it sits).
                If this pawl gate "seat" is what's broken then you'll want Part #: M0264570 which is on the very next page of the duplex parts layout.
                Omertà
                • Doug James
                  • Jan 2012
                  • 935
                  Thanks so much That is a HUGE help... Yeah the paper guide pawl bar holder in the rear is broken and it won't stay in....
                  • Doug James
                    • Jan 2012
                    • 935
                    Very Grateful !!! Thank you again !!
                    • Polarbear
                      • Feb 2012
                      • 1070
                      Hi All
                      going by the photos in the post quoted above, the part being advised is the wrong one. We have had several of these clips fail, and it takes quite a bit of time to replace.
                      P/n: M0264570. GUIDE PLATE V TRANSPORT: DUPLEX (NO 116 in the attached pdf.) is the correct part. It is a black guide (almost the size of the right door, as it fits inside.)
                      Press the GREEN button!!
                      • FrohnB
                        • Jul 2017
                        • 1919
                        Originally posted by Polarbear
                        Hi All
                        That's the number I gave him in my second post. It even has it in the "quote" you used from my post. wrong one?? I'm not talking about the actual pawl gate, was just circling that to show him that is what seats into the "clip" on the guide mentioned. The first post picture was showing him the part HE mentioned and where we've seen that break.
                        Omertà
