Ricoh mp c5503
  • heath03
    • Jul 2018
    • 80
    Ricoh mp c5503
    installed a its belt. i think its faulty
    tried on 2 different its units to make sure unit wasn't faulty
    any ideas
    • 37488
    Re: Ricoh mp c5503
    Maybe try scanned images instead of crappy photos.
    And include a complete typed description of the problem you are having.
    • heath03
      • Jul 2018
      • 80
      Re: Ricoh mp c5503
      the black drum and pcu are fairly new. the its belt was due for change 460,000 on it. i change the belt and we think the belt is faulty.
      your thoughts
      ty
        • 37488
        Re: Ricoh mp c5503
        It the sample was printed LEF, you might want to check that the PTR is making proper contact with the ITB at both ends.
        • HitMan
          • Aug 2015
          • 170
          Re: Ricoh mp c5503
          Is the panel at the back of the black pcu and dev unit installed correctly? Does look drum related but those speckles at the top of the scanned image could be because the ITB isn't cleaning properly.
          Sent from my SM-G930F using Tapatalk
          • heath03
            • Jul 2018
            • 80
            Re: Ricoh mp c5503
            it does it in the same spots when printing color as well.
            • HitMan
              • Aug 2015
              • 170
              Re: Ricoh mp c5503
              Maybe try doing single colour full page prints to see if you can narrow it down to a specific drum unit. If they all have the same marks it could be the itb. Do keep in mind that the black drum is in contact with the itb at all times though
              • heath03
                • Jul 2018
                • 80
                Re: Ricoh mp c5503
                leaning to faulty belt?
                • HitMan
                  • Aug 2015
                  • 170
                  Re: Ricoh mp c5503
                  Yeah looks like the image transfer belt could be the issue. If it was the fuser, the image would still be on the page and you could wipe it off with a finger. Is it possible the ITB has a tear in it?
                  • heath03
                    • Jul 2018
                    • 80
                    Re: Ricoh mp c5503
                    no but it lQQked funny, kind of looked like it had some wrinkles in it. i got from parts room they are sending a new one.
                    ty for the help
                    • HitMan
                      • Aug 2015
                      • 170
                      Re: Ricoh mp c5503
                      No problem [emoji106]
                      • FrohnB
                        • Jul 2017
                        • 1919
                        Re: Ricoh mp c5503
                        When you changed the belt did you make sure to have the "number on edge" towards rear side?
                        Also when changing those belts or cleaning units, we usually powder on some yellow toner a few inches wide just to the right of the cleaning unit (when viewed from front) as a lubricant, and then give the belt a spin for a full rotation to prevent the blade from turning up.
                        Omertà
                          • 37488
                          Re: Ricoh mp c5503
                          It would have thrown a service code code if it wasn't.
                          The loss of image on one side only coupled with having some wrinkles almost has to be the PTR not making proper contact with the ITB. There are a number of threads that deal with PTR problems.
                          • Zaxxon
                            • 608
                            Re: Ricoh mp c5503
                            Gets my vote, seen this several times. The bracket for PTR is dislocated.
                            Please start you post with brand, model, problem.
                            • emiliorsg
                              • Jul 2018
                              • 141
                              Re: Ricoh mp c5503
                              I also think that you have a problem with PTR unit.
