Ricoh MPC 5503
  • heath03
    • Jul 2018
    • 80
    Ricoh MPC 5503
    i replaced the ITB belt and the machine is still going light to dark. the fuser has less than 30 k on it
    the black pcu and developer around 35k.
    ty in advance for any help
    Re: Ricoh MPC 5503
    did you run adjusts/inits on items replaced?
    OEM parts/supplies?
    did you re-check all contacts?
    post the BC pages for the bias/volts settings...
    • copier tech
      • 8144
      Re: Ricoh MPC 5503
      Why did you replace the transfer unit?
      Does the issue only happen in mono?
      run the colour test prints in service mode this will help you narrow down the cause.
      • fshead
        • 2376
        Re: Ricoh MPC 5503
        You need to give more info.
        total b/w and color meters on machine,using OEM/AFTERMARKET TONERS?
        Why did you change ITB belt?torn worn? and didnt change the cleaning unit??????
        did you try sing color copies?
        is the copies from 1 tray or 81/by 11 reduction..
        hows the fuser look?
          • 37488
          Re: Ricoh MPC 5503
          So you did not like the answers we gave you on your previous thread and thought we would answer a new thread differently? If one of my junior techs had ignored advice and replace an expensive assembly, he would be looking for a new job.
          • hossam
            • Aug 2010
            • 70
            Re: Ricoh MPC 5503
            What type of paper you are using?
            i think it's Fusing problem.
            • fshead
              • 2376
              Re: Ricoh MPC 5503
              i agree fusers can cause like uneven,lite CQ too and that is why i asked him to expand his post
              • mikadonovan
                • May 2008
                • 2931
                Re: Ricoh MPC 5503
                Clean the ID sensors/optics and then run ACC.
                NEVER ASSUME ANYTHING
                • heath03
                  • Jul 2018
                  • 80
                  Re: Ricoh MPC 5503
                  ITC belt replaced bc it had 460,000 on it. the fusing unit has 751 impressions on it
                  PCU has 250392 dev the same. the PTR unit has 409571 on it, i just don't think that would do that but ill replace it.
                  the toner is not OEM toner
                  • fshead
                    • 2376
                    Re: Ricoh MPC 5503
                    a new ITB unit and you did not think a new cleaning unit would be in order........at 1/2mil
                    • heath03
                      • Jul 2018
                      • 80
                      Re: Ricoh MPC 5503
                      yes sir that was replace as well OEM
                        • 37488
                        Re: Ricoh MPC 5503
                        OEM usually means after market not Genuine Ricoh.
                        • Copy One Loja
                          Re: Ricoh MPC 5503
                          check the transfer roller unit and the transfer roller stops.
                          I hope it helps you.
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            Re: Ricoh MPC 5503
                            If there is a lot of cloged toner on the fusing unit guides, than i think it is F.U.
                            Because in that case, the toner that went of the page must stay somewhere, not?
                            • Zaxxon
                              • 608
                              Re: Ricoh MPC 5503
                              Do SP 1103 002 in printer SP mode and show us the printout.
                              My guess is PTR bracket stuck in one side, 2 sec. fix, just pop it back.
                              Please start you post with brand, model, problem.
