Reset to factory settings? Ricoh 3045
  • kfiresmith
    • Sep 2025
    Can't telnet to it, can't rsh, the web interface shows nothing but a big ol' 404...
    Anyone got any ideas for dealing with this SOB?
  • Captain Scott
    • Dec 2008
    • 166
    May help!
    Print out config page, take note of any extra network settings eg DNS, SMTP, Domain name. Check if there is any ranges entered on the config page under the access control list. If not do a NCS memory clear which resets the network settings.
    • kfiresmith
      Could you please point me towards an explanation / process for doing such a thing? Google was unhelpful:
      ncs memory clear - Google Search
      I get the redirect after entering it's hostname, so I know it's something jacked in the web engine.
      IE: browsing to http://my-broken-copier.domain.com redirects me to it's http://my-broken-printer.domain.com/...r-the-rest.cgi
      • nmfaxman
        • 1702
        Both the reports and memory clear are in service mode.
        Reports are in mode and memory rest is in process.
        Scroll through each mode and find them.
        Better yet RTFB.
        • kfiresmith
          Better yet RTFB.
          DCWAFB...
          I'll see if any of that is in the l-user guide.
          • Captain Scott
            • Dec 2008
            • 166
            Try this!
            You will need access to the service mode so maybe not best suggestion.
            I would start with a laptop and a cross-over cable set laptop to same range as m/c and test eg ping,printing and web image monitor. If still no luck try to print something using a LPR command from command prompt, if still no good most likely a hardware fault.
            If all works fine with the laptop make sure when plugged into Lan that you see a green light on the m/c's network card (if not possible port/switch/vlan problem. Try setting m/c to DHCP and see if the device picks up an IP address. Compare DHCP info to static info.
            Just a few ideas that may help otherwise ring for service!
            • Jomama46
              • 2900
              If you're trying to access with Server 2003 you may have to adjust the security settings.
              sigpic
              A+; Network +; PDI+
