MP c4500 copy quality problems
  • saramwoo344
    • Jun 2019
    • 3
    Hello.
    This is sung.
    I have vertical lines on everything i copy, the lines are always in the same place.
    My copier is Richo MP c4500.
    This is original source.
    This is full color copy.
    This is black and white copy.
    What problems is there?
    Thanks.
    • 37532
    Re: MP c4500 copy quality problems
    Vertical means absolutely when talking about the copier process. Is it in the main scan or subscan direction?
    • saramwoo344
      • Jun 2019
      • 3
      What do "the main scan or subscan direction" mean?
      • saramwoo344
        • Jun 2019
        • 3
        Originally posted by nguyen hong sonn
        check Transfer Roller
        [ATTACH=CONFIG]42918[/ATTACH]
        I'll try.
        Thanks.
        • fshead
          • 2376
          Originally posted by saramwoo344
          hello.
          This is sung.
          My copier is richo mp c4500.
          [ATTACH=CONFIG]42915[/ATTACH]
          this is full color copy.
          [ATTACH=CONFIG]42916[/ATTACH]
          this is black and white copy.
          [ATTACH=CONFIG]42917[/ATTACH]
          what problems is there?
          Thanks.
          looks like divine intervention...any halos too?
            • 37532
            If you were a trained Ricoh tech you would have learned that in the Copier Basic Course.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Agreed..!!!
              This is NOT a forum that end users generally come to ...it's not Fixya.
              It's more of a forum for technicians to talk shop...seek help with issues similar to yours etc etc.
              If you're an end user then the only advice that you should be receiving is to seek out a qualified technician.
              • mikadonovan
                • May 2008
                • 2931
                Appears to be an issue with K PDCU.
                NEVER ASSUME ANYTHING
                • guitar9199
                  • Sep 2016
                  • 1100
                  The model was released in 2006. I would recommend a replacement....13 years is a little old for those machines. I'm not certain WHEN... but parts availability WILL be an issue sooner rather than later. Once you get a part listed as "No longer available" that machine will be dead in the water.
                  • FrohnB
                    • Jul 2017
                    • 1919
                    Dirty Black laser glass.
                    Or Spent black Dev. Unit.
                    Omertà
                    • GIUBOSS
                      • 1436
                      In the meantime, if you want to have fun disassembling the black photoconductor unit and cleaning it, it will certainly not worsen the quality ..
