Ricoh MP C5503 SC186
  • copier tech
    • 8139
    [Error Code] Ricoh MP C5503 SC186
    Hi all,
    Manual states:
    Any guys out there seen this issue before?
    I'm looking at replacing the CIS but very high cost part!
    Any suggestions appreciated!
  • davel
    • Oct 2011
    • 1101
    Re: Ricoh MP C5503 SC186
    I presume you have tried cleaning it,.
    • copier tech
      • 8139
      Of course many times!
      • semi
        • Sep 2008
        • 193
        • skinnyb
          • Jul 2008
          • 291
          I've replaced several. Make sure the white roller in the door is spotless as it is the "white plate" for the CIS
          Sent from my LM-V405 using Tapatalk
          • copier tech
            • 8139
            Cheers for all the info.
            Maybe a silly question but to get the machine running again as a temp measure is there a way to disable the single pass & set the DF to dual scan!?
            • Brianneoe
              • May 2015
              • 318
              I had this on a B\W 6002 series. Just to the left of the CIS is a mylar strip that will collect junk..Getting under it and cleaning it off resolved my problem. Its quick and easy.
              Good luck
              • copier tech
                • 8139
                This was the fix, just a small bit of hard toner etc cleaned off & it worked.
                My tech was a little embarrassed......................
