MPC3003 Light copies
  • Debs1964
    • Oct 2010
    • 1693
    Re: MPC3003 Light copies
    Originally posted by Oze
    Hey all...
    I have an MPC3003 in the field that needed a black pcdu replaced.
    Before I did the service I noticed that the copies from the ADF and Platten were really pale.
    Swapped in the new pcdu and ptr assy.
    Cleaned the laser slit glass,optics etc.
    Copies were STILL shocking.
    Returned to the machine the next week(it's 2 hours from the workshop) and fitted a new lamp and SIO board...
    A very slight improvement but still not as good as the print engine.
    Any ideas?
    Try doing a memory clear just on copier application
    There are 10 types of people in this world, those who understand binary maths and those who don't
    • Oze
      Ricoh Fanboy
      • 1663
      Good idea Debs...I did a memory clear on the scanner application but not the Copier application.
      • eddy out
        • Oct 2016
        • 359
        scanner, for sure. optics?
        • Lagonda
          • Aug 2008
          • 1649
          #19
          I hope I'm not trying to teach my granny to suck eggs but you did remember to reset the ITB release lever so the belt is in full contact with the drum?
          I got caught the other week.
          • Oze
            Ricoh Fanboy
            • 1663
            #20
            Sure did ..
            Luckily(or unluckily) for me the fault was there prior to fitting the new pcdu...so it was an existing fault.
            The customer never noticed it...I did.
            Now that they've seen it...they can't unsee it
            • allan
              RTFM!!
              • 5462
              #21
              And if you scan to a PC?
              Whatever
              • Mark Bbb
                • Jun 2012
                • 1662
                #22
                Remember Ricoh mp2550?
                Same issue after about 60K: kopie bad, print ok.
                Only solution was to replace the PCU.
                I think those Japs knows what they are doing to sell more PCDU's.
                No?
                • davel
                  • Oct 2011
                  • 1107
                  #23
                  Read the OP, PCDU was changed.
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    #24
                    He said that the copy QA was better after replacement
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      #25
                      Replaced the complete PCDU and I DID notice that the scanned upload doesn't look as bad as it does first hand
                      • HitMan
                        • Aug 2015
                        • 170
                        #26
                        If the copies are still bad you want to open the laser and clean the mirrors inside. Then run acc providing you have also cleaned the mirrors in the scanner
                        Sent from my SM-G930F using Tapatalk
                        • Oze
                          Ricoh Fanboy
                          • 1663
                          #27
                          Just an update to this:
                          Went back to the machine for more testing and it's sorted itself out.
                          Copy quality is good now.
                          The only thing I did was run ACC for copy but they had previously copied jobs laying around the room and they looked fine as well.
                          Just a machine messing with my head...as usual
                          • JayPaul
                            • Oct 2012
                            • 305
                            #28
                            Just so I know, when you replaced them you set new unit in Process part of Service mode? then turned machine off and on, then did the rest etc
                            • Oze
                              Ricoh Fanboy
                              • 1663
                              #29
                              Yep...everything was done as usual.
                              Each time I fit a PCU or a PCDU I also run ACC....just one of those weird issues.
                              • fshead
                                • 2376
                                #30
                                For me the 03 colors are not as dark/dense as the 02s.
                                I doubt the drums go but can see the developer breaking down and causing CQ issues..
