MPC5503 Fusing sleeve belt unit - 400k?
  • windcopier
    • Apr 2019
    • 51
    Hi !
    I have using New Ori Fusing sleeve belt unit for quite sometimes,
    But i encounter the Sleeve Belt ONLY sometimes only can use around 150k to 180k and the Heater still have no problem at all.
    Look at the Service Manual Preventative Maintenance it only show that Fusing sleeve belt unit Replace 400k.
    Is it really the Sleeve Belt only can last long untill 400k ? or include entire unit?
    Can anyone share some thought?
    My customer are also using both Recycle Paper and New paper also due to cut cost.
    Thanks for advice.
  • davel
    • Oct 2011
    • 1104
    Re: MPC5503 Fusing sleeve belt unit - 400k?
    OEM part or aftermarket? Use sh1t paper or exceed usage ratio equals less life.
    • windcopier
      • Apr 2019
      • 51
      It is new and original part.
      Not oem . Not aftermarket.
      • FrohnB
        • Jul 2017
        • 1919
        We generally just change the sleeve after 300 - 400k and then change the Press Roller and bearings out after the 2nd maintenance cycle (800k) along with some of the gears that tend to lose teeth. Thermistors and all the other stuff seem to last quite a bit longer.
        Omertà
        • windcopier
          • Apr 2019
          • 51
          Thanks for sharing.
          may be i did not change the bearing
          • skinnyb
            • Jul 2008
            • 291
            My sleeves normally go full life unless a user starts digging with a letter opener or something (then they $$$ buy the sleeve). I always replace sleeve unit, pressure roller, bearings and the 3 gears especially if they are the old style. Also grease them and the bearings and they (gears) last longer and don't turn into dust quite as easy. Never replaced a thermistor yet. They typically just have some toner on them and I clean it off.
            Sent from my LM-V405 using Tapatalk
            • anothertech
              • 1769
              I cleaned one of those themsitors one time, I just kinda scraped it with my finger nail. Then it didn't work anymore and I didn't have a spare. Lesson learned, don't clean it unless you have a new one to replace it with.
              • windcopier
                • Apr 2019
                • 51
                thanks for the sharing post.
                Maybe the pressure roller also effect. Next time i will try for it. Thanks
                • windcopier
                  • Apr 2019
                  • 51
                  I also never change thermister before since 750k.
                  looks like can be last long.
                  • windcopier
                    • Apr 2019
                    • 51
                    Thanks for sharing.
                    I should do in this way
                    • eddy out
                      • Oct 2016
                      • 359
                      may I ask if this original post is replacing the sleeve "only" onto a used sleeve unit? I've personally replaced the sleeve unit, press roller and bearings, plus 3 gears and two thermistors. Are you guys really getting 750k on thermistors with no damage to the pressure roller?
                      • windcopier
                        • Apr 2019
                        • 51
                        750k should able to reach. But it depends your sleeve and sleeve unit.
                        if your sleeve and sleeve unit giving you a problem. Your thermister life spend will be shorted.
