Bio-T Max replacement
  • mommok
    • Jul 2014
    • 48
    [Misc] Bio-T Max replacement
    For as long as I have been a tech my company has used Bio-T max to clean feed rollers. The company that make Bio-T max no longer sales it in 1 or 5 gal pails, can only buy in 55 Gal barrels. we defiantly do not need 55 gal of the stuff. I was wondering what other people use to clean feed roller, rejuvenate the rubber and doesn't stink.
    • 23006
    Re: Bio-T Max replacement
    LMGTFY
    It's orange oil based, and not too concentrated that it can damage plastic parts at 100%.
    For tires that are desperately in need of replacement use WD-40, but keep in mind that WD-40 DOES DAMAGE PLASTIC, and removes material from the roller. I use it as a last desperate measure when the rollers are on order. =^..^=
      • 37447
      Ricoh puts a Scrubs hand cleaning wipe in their technician supply kits that they used to include in every PM kit. Not only do they work good for your hands but also are good on feed tires that have become impregnated with dust and paper lint. Not quite as good as the little bottles of water-less hand cleaner with grit that they put in the PM kits many years ago but still acceptable.
