Color Run
    • 37491
    #16
    Re: Color Run
    Originally posted by xlbizs
    the faulty MPC5503 actually at my office with another unit of MPC5503. we did try to clean up the ID sensor, at SP Mode we try to do Force Line Adjustment according the step (we make it done for other MPC). still the same.
    We exchange LD, ITB Unit, Magneta PCU one by one with the good MPC5503. Still the same. (All parts from the faulty unit install at the good one with no problem at all). For this case, the Magneta color bar is running difference way, left and right even after we manually adjust it.
    Changing the broad is the last one we try and the print out back to normal with the original parts.
    Thanks for the sharing.
    Exactly how did you "try" to clean the ID sensor assembly? If you did not do it correctly, you may have damaged the sensors.
    • mikadonovan
      • May 2008
      • 2931
      #17
      Re: Color Run
      Last time I tried changing my broad, she got pissed and left. Not sure if it fixed anything, but it sure is quieter now.
      NEVER ASSUME ANYTHING
