Color Run
  • xlbizs
    • Jun 2009
    • 66
    Color Run
    Good day,
    - This Ricoh MPC5503's color print out run. only magenta to Right and left, center Ok.
    - Try to change LD, ITB, ID sensor & Magenta PCU . Same result
    - Adjust Main Dot at SP Mode, 1 side ok than the other still run
    any idea.
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Color Run
    Your colors are misaligned.
    Have you tried running SP2-111-004 Forced Line Adjust?
    I'd have thought that replacing the itb assy and then running full music would have set this right?
      • 37532
      Re: Color Run
      Before doing forced line position, properly clean the ID sensor assembly. I have had that alone pull colors back into alignment.
      • Debs1964
        • Oct 2010
        • 1693
        Re: Color Run
        Try doing
        ACC recall SP5-610-4
        ACC recall SP1-101-1 in printer SP
        Process control SP3-011-1
        Check process control result in SP3-012-12 (should be 11111111)
        Line adjustment C (or D) if it's on this model SP2-111-3 (or 4)
        Line adjustment A SP2-111-1 execute twice
        Then try printer test page again
        Obviously make sure ID sensors are clean prior to doing this
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • xlbizs
          • Jun 2009
          • 66
          Re: Color Run
          IMG-20190704-WA0016.jpg After changing this broad, color back to normal. all items (ITB, ID sensor, Magenta PCU, Laser unit) put back.
          • keithxxiii
            Just a tech
            • Nov 2014
            • 469
            Re: Color Run
            Cool, you have changed the IPU.
            You could have tried the steps suggested by other techs. Anyway, it's your call. $$
            Aye! Cut the crap
            • sandmanmac
              • 3981
              Re: Color Run
              x2!
              So many times a simple image defect makes people immediately start changing circuitry and Major components before even doing the most basic adjustments
              • skinnyb
                • Jul 2008
                • 291
                Re: Color Run
                Originally posted by sandmanmac
                x2!
                X3. I have seen this many times. Simple clean id sensor and do line position adjustment always brought mine back in line. Especially older models...
                Sent from my LM-V405 using Tapatalk
                  • 37532
                  Re: Color Run
                  I did have 1 machine where that would pull it back in and the next morning it would be off again. Machine was only a couple of weeks old so I called our regional rep and he said that Ricoh had been having some problems with ITB slippage. He sent me a new ITB assembly and problem went away.
                  • anothertech
                    • 1771
                    Re: Color Run
                    I had one that would not hold for more than a day or two also, ended up replacing the ITB assy.
                    • skinnyb
                      • Jul 2008
                      • 291
                      Re: Color Run
                      I concur but have not seen it on this particular unit/design. The older ones (ie 5000,5501,5502) I have seen it a few times. Usually I can clean the big drive roller really good and replace the belt though.
                      The newer design I have only replaced the belt a handful of times. They last a long time, even past pm time normally. Normally they rip or shred down the side as a typical failure in my experience. I always replace the cleaning unit regularly, they are weak and get full of fuzz and start streaking.
                      • Oze
                        Ricoh Fanboy
                        • Jul 2008
                        • 1663
                        Re: Color Run
                        Toner underneath the transfer belt does it as well.
                        A pcdu goes overlife and dumps on the ITB...tech changes PCDU but now the colors are misaligned due to slippage from excess toner inside the ITB assy.
                        • xlbizs
                          • Jun 2009
                          • 66
                          Re: Color Run
                          the faulty MPC5503 actually at my office with another unit of MPC5503. we did try to clean up the ID sensor, at SP Mode we try to do Force Line Adjustment according the step (we make it done for other MPC). still the same.
                          We exchange LD, ITB Unit, Magneta PCU one by one with the good MPC5503. Still the same. (All parts from the faulty unit install at the good one with no problem at all). For this case, the Magneta color bar is running difference way, left and right even after we manually adjust it.
                          Changing the broad is the last one we try and the print out back to normal with the original parts.
                          Thanks for the sharing.
                          • davel
                            • Oct 2011
                            • 1107
                            Re: Color Run
                            You say you tried to clean ID sensor does that mean you could not get it clean?
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              Re: Color Run
                              the only time we have broken boards on a ricoh is when a road worker has tear through a power cable in the direct neighborhood of the company. And when that had happend, it is a inssurance issue...
