Ricoh pro c751ex sc 144 and if i close the doors show sc 670
  • Eris lleshi
    • Mar 2018
    • 4
    [Error Code] Ricoh pro c751ex sc 144 and if i close the doors show sc 670
    Code
    SC144
    Description
    SBU Communication Error When the machine was switched on, or when the machine returned to full operation from the energy save mode, the machine could not access the SBU register, or the SBU register values are abnormal. Note: The ASIC IDs read during automatic adjustment of the SBU can be displayed with SP4600 (SBU Version Display).
    Causes
    SBU-BCU harness loose, disconnected, defective SBU board defective SIOB board defective BCU board defective
    while the scaner do not turn on and can not put into operation it's off
    i think it's a relay voltage but i can't find in SBU or i don't know
    please help me!
  • GIUBOSS
    • 1437
    Re: Ricoh pro c751ex sc 144 and if i close the doors show sc 670
    I would disconnect the ardf to see if it still reports the error code, so think of the damaged bcu ...
      I do think, that will throw it's own specific ecode...but it's a start
        Originally posted by Eris lleshi
        Code SC144
        Causes:
        while the scaner (scanner) do(es) not turn on and cannot put into operation it's off
        ** operation ? ** some codes will not allow functions.. but TECHS can enter Service/Tech mode ...can you access Tech Mode?
        please help me!
        ** if you have a true service manual.. the circuit layout is in there **
        • Eris lleshi
          • Mar 2018
          • 4
          Where is the BCU please (the scanner motorr turn on with output ,but the exposure lamp no)
          • davel
            • Oct 2011
            • 1108
            You need a trained tech with a service manual.
