MP C307 Magenta Background
  • jshah
    • Aug 2013
    • 53
    [CQ] MP C307 Magenta Background
    MP C307 magenta background problem, Has anyone seen this on this model? sample print attached.
  • allan
    RTFM!!
    • 5462
    Re: MP C307 Magenta Background
    Drum not getting charged?
    Whatever
    • DonPedro
      • Feb 2019
      • 14
      There are no margins? No leading edge ?
      • jshah
        • Aug 2013
        • 53
        no margins. no leading edge
        • keithxxiii
          Just a tech
          • Nov 2014
          • 468
          I agree with allan. In a mono machine, if the charge unit is defective, you get BLACK or for some other models, BLANK.
          The same goes for this. Check your PCU's charge unit. One of the edge is grounded.
          Aye! Cut the crap
          • UNICORNico
            • May 2018
            • 308
            Re: MP C307 fondo Magenta
            Good mates.
            It may also be that the device detects the original as "paper currency" or similar. I had a case where something similar happened to me.
            "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
            • Coptech
              worker drone
              • 460
              Exactly. That paper looks like it was colored before it went into machine. No charge at all on magenta would still have the lead edge and side erase voids.
                • 37481
                Laser printers are write to no charge. So if you have a problem that is causing a drum to not be charged fully, you will get full bleed color across the entire sheet of paper. If someone has taken the charge roller out to clean it, the charge contact for the roller may have gotten bent.
