New IMC series remote engineer app
  • Polarbear
    • Feb 2012
    • 1070
    Good day gents
    I have been told that there is a "remote engineer" app that can be enabled on the new IMC series, that allows something similar to Teamviewer, to assist the customer in remotely repair service issues.
    Does anyone know how to enable this, as the field service guide is not much help.
    TIA.
    Press the GREEN button!!
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: New IMC series remote engineer app
    It should already be on the device. If you press and hold the banner on top of the screen for five seconds it should kick into life. If it doesn't, go into the apps section of panel SP and set it to auto start. As for the PC side of it to access the machine remotely, I'm not sure where to get that from but it should be on my-ricoh.
    Hit it.
    • keithxxiii
      Just a tech
      • Nov 2014
      • 468
      You need an OPTIM ID to access the remoteconnect support enabled device.
      Aye! Cut the crap
      • Polarbear
        • Feb 2012
        • 1070
        Optimid?
        I have a registered my Ricoh login
        Sent from my SM-G950F using Tapatalk
        • keithxxiii
          Just a tech
          • Nov 2014
          • 468
          Originally posted by Polarbear
          Optimid?
          Here's the link, OPTiM ID - Login
          BTW, there are 2 features available for new SOP V2.
          RemoteConnect Support and Remote Operation Panel.
          RemoteConnect Support requires activating the app and of course the OPTIM ID.
          I often ask the customer to grant me access to teamviewer, and from teamviewer I control the device using remote operation panel.
          Aye! Cut the crap
          • Polarbear
            • Feb 2012
            • 1070
            Hi keithxxiii
            Silly question - how does one obtain a login for OPTIM - is there a subscription charge or how does one register for the login?
            • keithxxiii
              Just a tech
              • Nov 2014
              • 468
              Hi keithxxiii
              This should come from Ricoh. If you are a partner, ask the guys from ricoh team.
              Aye! Cut the crap
              • Polarbear
                • Feb 2012
                • 1070
                Thanks.
                • aktasson
                  • Feb 2017
                  • 201
                  Good day gents
                  TIA.
                  It's called Remote Panel Operation and RemoteConnect Support? It's in SOP V2.5 integrated. I only have a german manual to activate it.
                  Doc page no 414 in met-mf3_fsm_en_final_141218.pdf.
                  • aguatepe
                    • Jul 2015
                    • 28
                    In case it helps you, from WIM there is an option in the left menu to be able to connect remotely to the machine (see the panel and manage it).
                    The technician should first connect to your computer through teamviewer to be in your network.
                    • mikadonovan
                      • May 2008
                      • 2931
                      Good day gents
                      TIA.
                      On the Ricoh site, go to whatever model youre dealing with and find it under "special/custom firmware. I loaded it up on a c6004ex the other day to check it out. As far as a customer using this thing is a really bad idea, as you will see after you have dicked around with it for a bit. Its pretty cool, and it works. Fat fingers do not play well with this app.
                      NEVER ASSUME ANYTHING
                      • CableGuy
                        Impulse Drive Engineer
                        • Oct 2008
                        • 417
                        Hi. Not sure that's the app I was thinking of. I'm talking about the one where you can do input/output checks on the screen from the app.
                        Not the one where you remote into the machine.
                        Cheers
                        • aktasson
                          • Feb 2017
                          • 201
                          Cheers
                          It's called 'cesa' or something like that. I used it first at hardware training course and personally never used in the field. You can download it on my-ricoh.
                          • mikadonovan
                            • May 2008
                            • 2931
                            Cheers
                            It's called the Customer engineer tool-engine diagnosis, listed under special/custom firmware.
                              • 36833
                              Cheers
                              If by "the screen" you are referring to the operation panel, then ut us not an app. It is in the Service Program. SP 5803 INPUT Check and SP 5804 OUTPUT Check.
