White Vertical Streaks on blue prints
  • Kwaku01
    • Aug 2018
    • 121
    Hi Everyone,
    Any help would be greatly appreciated. I'm getting white vertical streaks on blue...please see attached image.
    Thanks in advance!
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: White Vertical Streaks on blue prints
    Laser glass dirty or dev unit shot. What model?
    Hit it.
      • 37364
      What is the direction of paper feed?
      • barratec
        • Jun 2008
        • 162
        Drum unit cyan.
        • Codex
          • May 2008
          • 701
          I think it's both
          Inviato dal mio SM-G935F utilizzando Tapatalk
          Memento Audere Semper
            • 22999
            It could be either. Visual inspection is all you need on those two items. =^..^=
            • Kwaku01
              • Aug 2018
              • 121
              - Ricoh c2503
              - Glass already cleaned.
              What do I do if it's the dev unit shot?
              Thanks for your feedback.
              J
              • Kwaku01
                • Aug 2018
                • 121
                Originally posted by barratec
                Drum unit cyan.
                - Ricoh c2503
                What do I do if it's the drum unit?
                J
                  Originally posted by Kwaku01
                  - Ricoh c2503
                  J
                  replace drum
                    - Ricoh c2503
                    J
                    rebuild/replace
                    • jonhiker
                      • 661
                      rebuild/replace
                      this is correct. there are probably chunks of dv blocking the dr blade. some folks run a business card or plastic mylar to see if the image changes.
                      • davel
                        • Oct 2011
                        • 1095
                        What are the PM counts, replace the dev unit.
                        Other colours look crap as well.
                        • Kwaku01
                          • Aug 2018
                          • 121
                          Please how do you check the PM counts?
                          J
                          • keithxxiii
                            Just a tech
                            • Nov 2014
                            • 468
                            The gentleman should check the service manual. No shortcuts please.
                            Aye! Cut the crap
                            • davel
                              • Oct 2011
                              • 1095
