ricoh mpc 4502 Jams going into fuser
  • 1stcavvet
    • Apr 2015
    • 231
    [Jamming] ricoh mpc 4502 Jams going into fuser
    Replaced a fuser film assembly that had previously blew a big hole in the film---shorted out and showed aSC544----replaced the film reset and started to test it out. jams sometimes with the leading edge just tucked in the fuser, sometimes rolled up under the fuser exit guide. when I pull the fuser forward to remove the paper you can here a weird clunk of pressure roller returning to home position. ANY IDEAS I think maybe rotation sensor failure, but I don't want to just start throwing parts at the machne. see some errors with this machine on some other treads Anyone else have any of these same fuser issues
    • 37488
    Re: ricoh mpc 4502 Jams going into fuser
    What is the jam code?
    Have you checked that you put it back together correctly? That is, did you follow the service manual steps in reverse order?
    • Brianneoe
      • May 2015
      • 318
      The Press roller drive gear may be slipping. There is a bulletin (number 21) that gives a new part number for that gear. AB014340. There is no serial number cut-in information but the bulletin is dated Feb of 2013. Also check the press roller lift cam operation. A new fuser unit will have a little resistance when you cam up the roller by hand.
      • MIGUELMARCHENA
        • Feb 2018
        • 195
        • Coptech
          worker drone
          • 460
          New press roller D1444057 comes with bearings and gear already installed.
          • Hoosierdaddy
            • Oct 2016
            • 181
            I bet the little white gear fell off in reassembly
            • FrohnB
              • Jul 2017
              • 1919
              Check the brown stripper plate. Sometimes gets bent, or the ends get bent. The slightest difference in gap towards the center can cause the paper to catch, fold over, and wrap around the press roller. Damage to leading edge when it jams?
              Omertà
