Ricoh mp5001. Black pages, half print after drum, charge, dev
  • Nexcell
    • Jul 2019
    • 7
    I had a device come around. It has no print on copies/scans/faxes. I replaced the drum, charge roller, and developer. It improved to where I was getting solid print on a 3rd of the page. I did a panic stop and it is only putting on a 3rd of the drum. I cleaned everything up pretty well. I opened the laser assembly and cleaned the little bit in there, and the glass.
    Let me know what you guys think.
  • keithxxiii
    Just a tech
    • Nov 2014
    • 468
    Re: Ricoh mp5001. Black pages, half print after drum, charge, dev
    How about the transfer assembly? Do you have any sample documents to show us?
    Aye! Cut the crap
    • davel
      • Oct 2011
      • 1099
      Get someone who knows what they are doing as the MP 5001 has no corona, so no grid to clean.
      • Mark Bbb
        • Jun 2012
        • 1662
        1. Throw the machine through the window.
        2. Pick it up, reconnect and put it on
        3. Is it still working? Repeat from start untill point 4.
        4. Total loss? YES! Now you can sell him a PRINTER, and get this piece of crap to the nearest dumping ground.
        • Nexcell
          • Jul 2019
          • 7
          I can get test sheets later. And I forgot to put that it is only printing on a 3rd of the drum, the end in the rear. Transfer assembly may be the next step.
          • FrohnB
            • Jul 2017
            • 1919
            If it's only writing image on 1/3 of the rear of drum, I would suspect laser unit (this is what creates the image on the drum). Do you have another machine you could swap lasers to test??
            The Transfer unit is there to "pull" the image from the drum onto the paper, and has nothing to do with "image creation", only "Transferring".
            Is your laser slit glass clean? Is there an obstruction between laser and PCDU path? Quenching lamps clean?
            Also, check the contacts on the rear of the machine (springs that can get bent - has happened a lot) and on rear of PCDU (clean/ not bent). Towards front of PCDU (if you split it in two) there's a metal shaft with a contact plate touching it. Make sure it is not missing or covered in toner/developer.
            Omertà
              • 37448
              Let me guess, you had toner spew from the toner supply tray. You thought some of the toner may have gotten in the laser unit so you removed the laser unit, took it apart and attempted to clean it. Bad idea. You most likely failed to first vacuum the toner piled up between the laser unit and the PCU. That toner is blocking the laser. Completely clean that area so there is no toner left that can fall into the laser unit when you remove the shield glass to properly clean it.
              • Nexcell
                • Jul 2019
                • 7
                I'll check when I get out there slim. Thanks
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  I had this issue a few times, due to bad drum grounding
                  • Nexcell
                    • Jul 2019
                    • 7
                    It was a bad connection with the drum bearing ground. A quarter turn more on the screw got it perfect. Thanks for the brain storming guys.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      Well, i'm not one of those who will begg for a reward when deserving it, but if there is a green card lost somewere, I think it could be that it belongs next to my name...
                      I don't want to be arrogant, pretentious, ore selfish, but everybody knows a reward from time to time can realy make that change you need.
                      It keeps the flush from going...
                      hmmm?
                      • anothertech
                        • 1766
                        I don't have a green card for you, but I do have this...
                        Good job Mark Bbb. You have helped a fellow tech in the time of need, Thank you.
