Ricoh SP-8100 Bag of Developer Part Number?
  • Doug.P
    • Aug 2015
    • 41
    [Misc] Ricoh SP-8100 Bag of Developer Part Number?
    I am looking for the part number for the bag of developer for an SP-8100DN. The parts manual I have does not show the part number for the bag of developer only the part number for the development unit. I know the developer is changeable because the Service manual shows dumping the old developer out and vacuuming the unit out and pouring in the new developer. But I can't find the right part number. Can anyone help me?
  • Zaxxon
    • 608
    Re: Ricoh SP-8100 Bag of Developer Part Number?
    B0039640 developer type 18 black
    AA012131 developer filter
    Please start you post with brand, model, problem.
      • 37047
      Your problem most likely is the age of the model. At the time that model was first manufactured, developer was considered a supply item, not a part, and therefore not included in the parts catalog. If you have the Product Support Guide, you can check it. Otherwise try the developer for the B/W MFP of the same age, B0799640 Developer Type 26 Black. You could also check with NA Trading as that is the only aftermarket toner/developer I would recommend using on Ricoh 35/45/40/50 ppm models.
      • Doug.P
        • Aug 2015
        • 41
        Thank You!!!
