Pro C5100S Replacement Message Won't Clear
  • Jonbelize
    • Aug 2019
    • 3
    Good day all, our machine asked us to replace the cleaning unit for the PCU for the color yellow. We did so and the message still appears, we cleared all PM counters and the problem still persists. Any help is appreciated.
    • 37357
    Re: Pro C5100S Replacement Message Won't Clear
    Two possible problems:
    1. Some models require that a particular door be open when you reset PM counters. You then have to cycle power before closing the door.
    2. The lube bar is installed incorrectly causing the end sensors to be activated. There is a bulletin on this.
    • Jonbelize
      • Aug 2019
      • 3
      Thank you for your response. We had already cleared the counters without knowing the doors had to be open, when we tried to reset it again the option to do so was greyed out. Do you have any pictures of what the lube bar sensors look like?
      • davel
        • Oct 2011
        • 1094
        Look in service manual/bulletin, once fixed see if other units are due for change. did you fit new unit or rebuild, was lube bar replaced?
        • Jonbelize
          • Aug 2019
          • 3
          I believe the lube bar was replaced.
          • anothertech
            • 1760
            read this over, I hope it helps.Near end alert.pdf
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Also...use SP3-701 (Manual new unit set) and scroll through to the cleaning units to reset them WITH BOTH SIDE DOORS OPEN.
              Those counters will be accessible rather than going in via the PM menu.
