MP C6502 can't clear message: Replace Cyan Cleaning unit
  • JUAN C DLS
    • Mar 2014
    • 14
    [Misc] MP C6502 can't clear message: Replace Cyan Cleaning unit
    I did replaced Cyan Cleaning unit on this MP C 6502; I did reset cleaning unit counter on SP Mode with side door open. same message on screen.
    I check several post on this issue and even interchange cleaning units with other colors, but message doesn't clears.
    Another tech advice me to replace whole Drum unit assembly (PCU unit), I dont have part number.
    Any other advice?
    Thank you !
    • 37620
    Re: MP C6502 can't clear message: Replace Cyan Cleaning unit
    MP C6502 and Pro C5100 are the same basic platform. Please see the following thread for help.
    Ricoh Pro C5100s - PCU Cleaning Unit Not Resetting
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Also...use SP3-701 (Manual new unit set) and scroll through to the cleaning units to reset them WITH BOTH SIDE DOORS OPEN.
      Those counters will be accessible rather than going in via the PM menu.
      • copier tech
        • 8213
        The 5110 has a sensor to detect when the lube bar has run out the out so needs to be replaced can not be reset.
        The 6502 is the office version this is done via PM counter so do manual new unit set as suggested.
        โ€‹
          • 37620
          From checking I linked the wrong thread on my previous post. It should have been http://www.copytechnet.com/forums/ri...24=#post794147 The bulletin posted by anothertech is the critical information.
          Considering the fact that I have worked more on C6502s than on the Production models, the problem with the lube bar wear sensors is the same. In fact almost all parts are the same since both are the same basic main frame. The main difference are the toner hopper assembly (different capacities), the control panel, added feature with the Pro and a couple of additional peripherals for the Pro.
          • Ricoh-ono
            • 340
            Had this happen a couple of times. Reset all the counters but message remains. Usually the contact switches for the lube bar. I make it a habit to open them up and widen the gap between the copper contacts every time.
            Do what you can, with what you have, where you are. ~Theodore Roosevelt
              so what you re saying is you give the lube bar more time to wear down and damage the $$$$ drum?.. your customers must love you when the drums fail due to WEAR MARKS!
              • Ricoh-ono
                • 340
                Nope. That would be your assumption. But hey those that can do and those who can't manage! Am I right?
                  • 37620
                  If you just follow the instructions in the bulletin, nothing else needs to be done.
                    • 37620
                    Obviously since you need to do unnecessary and unauthorized modifications, you must fall into the category of those who can't.
                    • Ricoh-ono
                      • 340
                      I'm familiar with the bulletin and again another wrong assumption. I've still had the message not reset after running through the SP's properly. The is gap on the contacts narrow on some of these units. The adjustment I make is a small one and does not disable the near end detection sensors.
                        hahaha you mean the "service manager" badge on my account? that comes from CTN setting that title due to the "Like and Thanks" i receive from posts/comments.
                        yes I have been a service manager... BUT I was always in the field following up on my techs .. making sure they did their jobs .. an fixed their F-up .. like making unauthorized/unapproved repairs.
