Ricoh MP C4503 jamming 11" paper
  • Drew Shackleton
    • Jul 2015
    • 7
    [Jamming] Ricoh MP C4503 jamming 11" paper
    I have an MP C4503 with 983K pages through it. Recently, it is jamming single sided 11" paper sizes (ie. 11 X 8.5 and 11 X 17"). 8.5 X 11 and 8.5 X 14" works fine. The 11" paper seems to "roll up" before it gets to the fuser entrance guide plate. 11 X 8.5 has J21 and 11 X 17 has J19 jam codes. Any thoughts would be greatly appreciated.
  • dalewb74
    • Feb 2018
    • 1159
    Re: Ricoh MP C4503 jamming 11" paper
    if you look in your service manual what does it say those jam codes are related to? what have you tried so far?
    • Coptech
      worker drone
      • 460
      Top of the head guess but is the heat sleeve past life and not always turning?
        • 37544
        We could help you more if you had included the jam code, JXXX.
        • Coptech
          worker drone
          • 460
          He wrote 19 and 21 depending on the paper size he was running. If memory serves, that is failing to make fusing exit sensor. I am sticking with fuser either press roller swelled on ends or heat sleeve dragging and not rotating freely.
          • skinnyb
            • Jul 2008
            • 291
            Yep that's where my money is. 900k plus, the Fuser is probably wack even if its been rebuilt before.
            Sent from my LM-V405 using Tapatalk
            • eddy out
              • Oct 2016
              • 359
              when the 3 gears wear down they leave a pile of debris at the back side under the fuser.... have you noticed that? I have seen the gears cause similar issues.
              • skinnyb
                • Jul 2008
                • 291
                Usually when the gears wear away for me they make a terrible racket and pretty much jam every time. I change the gears, bearings, sleeve and pressure roller as a set normally especially on the 03 engines then grease the gears and bearings liberally with Barrieta grease and the problem doesn't occur again normally. Dry gears wear away to nothing. Never replaced gears on the 04 and EX series, they are greased from factory. Not touched an IMC yet, anxious to see exactly what is different..
                • Drew Shackleton
                  • Jul 2015
                  • 7
                  This issue has been resolved, thank you to all that replied. I am not set up to remove this thread.
                  • Coptech
                    worker drone
                    • 460
                    Tell us what fixed it and let somebody else learn from this thread.
                    • Zaxxon
                      • 608
                      Noooo, he will keep this for himself
                      Please start you post with brand, model, problem.
                      • mikadonovan
                        • May 2008
                        • 2931
                        Maybe it was just wet paper and he decided not to let anyone know. Profile says he is a delivery guy, but he was formally trained on that wide format pos cw2200, which might put him in the supertech category. Hmmmm, what to believe. These people that receive help and don't follow up with the solution kind of piss me off. Makes me feel used, cheap and unappreciated, and I didn't even help him.
                        NEVER ASSUME ANYTHING
                        • morgansterne
                          • Oct 2007
                          • 83
