MP C4502 , error sc995-01
  • birdcopy
    • Aug 2019
    • 3
    Lanier MP C4502 reports SC995-01 error. Is there any way to fix this error?
    • 37483
    Re: MP C4502 , error sc995-01
    Defective BCU
    NVRAM Replacement error
    • anothertech
      • 1768
      You asked "is there a way to fix this error." The answer is, of course there is, there is a way to fix all errors. The trick is knowing how!
      • JayPaul
        • Oct 2012
        • 305
        Usually an engineer would post -
        What may have happened to the machine
        The SC code or fault
        What they have done to try and resolve it (important)
        Then they post in here for ideas
        Your post would assume you haven't yet done anything to try and fix the problem? or look up the sc code even?
        • fshead
          • 2376
          are you even a tech?
          i say enduser
          • sandmanmac
            • 3981
            "fixya" is down the hall on the left
            • birdcopy
              • Aug 2019
              • 3
              i say enduser
              Thank you. I have found this error, cause machserial number is different from ROM chip.
