MPC2003
  • AMS
    • Jun 2017
    • 73
    [Error Code] MPC2003
    I have one popping up an sc569. I replaced the pressure release motor and home sensor. I replaced the fuser. It would never do it while I was there running it. Today I saw it happen. When I was putting away my tools the pressure release motor I just put in started cycling on its own and it popped up the sc569. I read other post on this code and I really do not want to replace the whole motor unit if I dont have to. I do not have many of these copiers in the field. Are they supposed to cycle just sitting there not being used? I was wondering if it could be a bad paper transport IO board instead of the motor assembly since it ran on its own. Any input would be appreciated.
    UPDATE..I checked with another copier and after a few minutes after copying it does cycle the pressure release motor once. The one that has the code cycles 3 times before the code pops up. Called tech support and said it could be the board but not for sure. They also said check wiring harness. The motor assembly seems to be working fine because you can hear it cranking the fuser release shaft. I am guessing its going to be the motor assembly. But how knows. The sensor checks ok also.
  • Zaxxon
    • 608
    Re: MPC2003
    Did you check the firmware?
    Please start you post with brand, model, problem.
    • AMS
      • Jun 2017
      • 73
      Re: MPC2003
      Not this time. I had updated this copiers firmware about 8 month ago for other issues.
      • Coptech
        worker drone
        • 460
        Re: MPC2003
        The motor will run fine...It is the gear with the one way bearing that is slipping and causing your code. Motor runs one direction to drive and the other way to pressure and depressure.
          • 37382
          Re: MPC2003
          8 months ago on a CXX03? There was a time when it was a new update daily.
          • skinnyb
            • Jul 2008
            • 291
            Re: MPC2003
            This. The motor unit has all the above parts. Change the one way. I swapped a whole unit the first time then had one to rebuild.
            Sent from my LM-V405 using Tapatalk
            • blazebusiness
              SanDiegoCopierRepair.com
              • 1250
              Re: MPC2003
              That's the right advice from Coptech............the one way is almost always the cause. Assuming gear and sensor for rotation are ok, and that the fuser isn't seized up or too tight. If you can turn the pressure engage gear by hand to apply pressure and then fuser rollers/heat sleeve unit turn ok.....it's the one way.
              • mohan
                • Oct 2013
                • 86
                Re: MPC2003
                Have you checked the ferrite core rotation sensor at front of machine? they have a tendency to get unclipped.
                • AMS
                  • Jun 2017
                  • 73
                  Re: MPC2003
                  Thanks to all, it was the one way gear slipping. I had no clue it even used a one way gear in that assembly. Now I do!! Thanks again.
                  • blazebusiness
                    • 1250
                    Re: MPC2003
                    Glad you are up and working.
                    Very common issue on this model......we try to stock those ..... in a pinch you can use a file to rough up the shaft the one way rides on to get the customer up and running (if you don't have a one-way on hand).
