Ricoh pro c5100 sc 538-01
  • levantin
    • Aug 2019
    • 26
    I have ricoh pro c5100s to report the error where sc538-01 should be fixed. Looking forward to learning
  • davel
    • Oct 2011
    • 1108
    Re: Ricoh pro c5100 sc 538-01
    Call a trained technician, if you are a tech read your manual.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      SC538-01 ID Sensor Cleaning Fan Lock
      So, you may need to replace that fan if it has failed. You can't really expect to work on a copier without the factory service manual. If you are a tech purchase or download the
      D135/D136/D137/D138 service manual and on Page 4-399 you will find a diagram that shows the location of all the fans.
      Or, of course, you could call a tech if you are not one yourself. Hope this information helped.
      • Chimatoner
        • May 2020
        • 4
        I am having same error code sc 538-01, how did you fix yours, i replaced the id sensor cleaning fanfan but still no joy
          • 37560
          Start a new thread. Include all the details as to what led up to the problem and what you have already tried.
          • abdelhamed boda
            • Oct 2022
            • 8
            I solved this problem and the solution is as follows: You change the transmitter from another place and the two machines will work
            • abdelhamed boda
              • Oct 2022
              • 8
              • mikadonovan
                • May 2008
                • 2931
                NEVER ASSUME ANYTHING
                • Amoussou
                  • Oct 2022
                  • 6
                  Hello Master ,what transmitter do you talk about,I have the problem so, explain me thanks
                  • Zaxxon
                    • 608
                    Please start you post with brand, model, problem.
                    • Amoussou
                      • Oct 2022
                      • 6
                      I have change the fans n*15,16 and IOB bord
                      But the error is not going, that why I ask what transmitter exactly we need to change to resolve the problem
                      • abdelhamed boda
                        • Oct 2022
                        • 8
                        Originally posted by mikadonovan
                        Hello, my dear, here is the solution. Solve the fan that is at the bottom of the ink tanks. This is the first step. Clean it well. The second step. See page No. 4-416 in the service of the machine. There is a motor behind the machine that needs to be cleaned. Clean it and the machine will work without any problems..contact me. Anytime at +201114935976
                        • abdelhamed boda
                          • Oct 2022
                          • 8
                          • abdelhamed boda
                            • Oct 2022
                            • 8
                            • abdelhamed boda
                              • Oct 2022
                              • 8
