Ricoh pro c5100 sc 538-01
  • abdelhamed boda
    • Oct 2022
    • 8
    #16
    Re: Ricoh pro c5100 sc 538-01
    Originally posted by davel
    Call a trained technician, if you are a tech read your manual.
    Hello, my dear, here is the solution. Solve the fan that is at the bottom of the ink tanks. This is the first step. Clean it well. The second step. See page No. 4-416 in the service of the machine. There is a motor behind the machine that needs to be cleaned. Clean it and the machine will work without any problems..contact me. Anytime at +201114935976
    • abdelhamed boda
      • Oct 2022
      • 8
      #17
      Originally posted by Chimatoner
      I am having same error code sc 538-01, how did you fix yours, i replaced the id sensor cleaning fanfan but still no joy
      So, you may need to replace that fan if it has failed. You can't really expect to work on a copier without the factory service manual. If you are a tech purchase or download the D135/D136/D137/D138 service manual and on Page 4-399 you will find a diagram that shows the location of all the fans.
      • Amoussou
        • Oct 2022
        • 6
        #18
        Vraiment ne dis un grand merci,je ferai tel que tu as dis,et je te reviens et il est deux du matin ici donc demain je te t'appelle par WhatsApp.........grand merci
        • bat
          • Sep 2008
          • 140
          #19
          Remove Toner Bank Unit and check pin on metal plate that actuates switch.
          • Amoussou
            • Oct 2022
            • 6
            #20
              • 37491
              #21
              For those who do not know how to use Google translate.
              Ok I'll do and I'll get back to you, is it possible that the fans in the toner unit can be the cause?
              • anothertech
                • 1770
                #22
                We all know how to translate, I'm just refusing to do it. I wouldn't post English in a forum that was in a different language, thereby forcing everyone that wants to read it to translate it.
                • Amoussou
                  • Oct 2022
                  • 6
                  #23
                    • 37491
                    #24
                    Re: Ricoh pro c5110s .... besoins du firmwaire printer
