SPC262SFNw scan to email
  • GeorgeBest
    • Jul 2009
    • 525
    HI,
    Customer's question is why this machine don't work with the SSL/TLS protocol.
    He cannot get the adjustment for SMTP .
    When sending a scan to email he uses the user email adress as the sender,
    this is then blocked by office 365.
    also, despite version 1.16 the machine still does not come out of sleep mode, one mustten perform a power reset.?
    Someone more experienced with this model?
    Thanks in advance
    Gr George
  • illude2
    • 30
    Re: SPC262SFNw scan to email
    I have not seen a machine yet that can use office365 without a relay server or certificate added. It's a Microsoft "issue" not a Ricoh issue.
    • GeorgeBest
      • Jul 2009
      • 525
      I have, but this machine uses the users email as a sender's name.
      He says that you cannot enter a smtp sender email that is used for all scans?
        • 30159
        Don't think any RICOH support scan to email using TLS and is a requirement for Office 365
        I use gmail as machine supports SSL or other mail server.
        You can setup a mail relay in Office 365 IE connector but customers IT should set it up.
        • TonerMunkeh
          Professional Moron
          • 3865
          Use the customer's MX record as an SMTP server on port 25 with no authentication. Put their domain name in here to get their MX information:
          MX Lookup Tool - Check your DNS MX Records online - MxToolbox
          Hit it.
          • illude2
            • 30
            Do you mean auto specify sender name? I have attached some pictures of a typical setup.
            • GeorgeBest
              • Jul 2009
              • 525
              But this is not the webinterface of the SP C262, it has a different look..
              • guitar9199
                • Sep 2016
                • 1100
                [ATTACH=CONFIG]43456[/ATTACH]
                Part of the problem I see is Office 365 uses port 587..not port 25. If you follow these settings, you SHOULD be able to send.
                How to set up a multifunction device or application to send email using Office 365 | Microsoft Docs
                • GeorgeBest
                  • Jul 2009
                  • 525
                  it is port 576 or 25 . .
                  problem is the senders email adres, there is no tab for the input of the administrator email adress
                  • copier tech
                    • 8142
                    The two email addresses need to be the same for office 365
                    "e-mailadres apparaat" is the device email address/the from address
