MPC300 Image !
  • GeorgeBest
    • Jul 2009
    • 525
    MPC300 Image !
    Hi,
    Get this image first copy or print in the morning when machine is coming out of standby
    further prints are good..
    something with the cleaning ITB ?
    Swopped the ITB, but no results..
    Never seen it on an MPC300
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: MPC300 Image !
    moisture? Any hidden SC codes on the SC/data report?
      • 37481
      Re: MPC300 Image !
      I have seen similar ob other machines when PM counts are past recommended rebuilds on PCU.
      • guitar9199
        • Sep 2016
        • 1100
        Re: MPC300 Image !
        ITB Cleaning unit is likely shot.
        • fshead
          • 2376
          Re: MPC300 Image !
          Originally posted by GeorgeBest
          Hi,
          Thanks in advance[ATTACH=CONFIG]43481[/ATTACH]
          I cant tell if the sample is b/w or color but i usually set a machine up to do single colors via service mode and
          would try a yellow copy and see if the issues stays or leaves. did u pull the K drum and ck the charge roller.?dirty contact?
          As black is usually the 1st to fail,i like to separate a K drum issue from a color drum/ITB unit issue
          • GeorgeBest
            • Jul 2009
            • 525
            Re: MPC300 Image !
            But its only the first copy . . ..?
            • anothertech
              • 1768
              Re: MPC300 Image !
              Yeah, i'm to agree with this, ITB Cleaning.
              • GeorgeBest
                • Jul 2009
                • 525
                Re: MPC300 Image !
                But I swopped it . . .
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Re: MPC300 Image !
                  Can you switch off the machine just for one night to see if the problem remains?
                  What are the counters?
                  • davel
                    • Oct 2011
                    • 1103
                    Re: MPC300 Image !
                    Did you fit a new ITB cleaning unit or a used one?
                    • fshead
                      • 2376
                      Re: MPC300 Image !
                      I have found these ITB units and the spc430 units to run and run.
                      Thats just what i see.
                      I d say K drum might not be 100%
                      • keithxxiii
                        Just a tech
                        • Nov 2014
                        • 468
                        Re: MPC300 Image !
                        This happens on other models. Check your counters, maybe the it is time to change those PCUs and Transfer belt/blades.
                        Aye! Cut the crap
