Ricoh mp7500 self check during job, juming
  • m_donakov
    • 213
    Hi all mu ricoh mp 7500 juming rondom. Somtimes after 2000 pices print somtimes after 500 sheets. After that i must reset it with 107 turn of and then on and send job agin. If i dont do the reset just puI out paper it isnt continue to print juming every sheet in before fuser and there is blured image on paper. i dont have idea what it can be, so i thought that maybe self check during job cause this. Please can you help me if you know somthing or tell me how to turn off self check during job just to try.
    Mile
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Ricoh mp7500 self check during job, juming
    PLEASE use Google Translate...this was waaaaay too painful to try to read.
    • m_donakov
      • 213
      Hi i have a ricoh mp7500 which stuck across a different copy randomly. When it gets stuck I have to reset it with 107 to continue printing. Otherwise it continues to stuck each sheet
      • davel
        • Oct 2011
        • 1109
        Any service codes?
        • m_donakov
          • 213
          Originally posted by davel
          Any service codes?
          No service code, just paper stuck in front of the fuser with blured image.
          • davel
            • Oct 2011
            • 1109
            What does it display on panel.
            • m_donakov
              • 213
              Nothing, just a guide how to remove paper that is inside.
              • keithxxiii
                Just a tech
                • Nov 2014
                • 471
                can you at least send us the logging data? SP 5990-4
                Aye! Cut the crap
                  • 37652
                  If you have to enter SP mode in order to clear the jam, you are getting a Type A SC code, these are fusing unit related codes. The code is most likely displayed when the machine first stops. As soon as you open and close the door or try to cycle power a jam at power on, J001, is generated. So when the machine stops, look at the display before doing anything else. The SC should be displayed. Otherwise, before cycling power, check SP 7403 to see what the last 10 service codes have been. The cause of those codes need to be repaired before you totally crater the fusing unit.
                  • Zaxxon
                    • 608
                    Gear on hotroller broken?
                    Please start you post with brand, model, problem.
                    • fshead
                      • 2378
                      maybe provide the jam history,sc history??
                      why do you need to enter service mode????
                      jam dont clear?
                        jam dont clear?
                        Slim explained the need for service mode.. A code error. clearing just the jams will not clear error codes.
