Ricoh 907
  • carr
    • Sep 2019
    • 5
    Ricoh 907
    Hello All,
    I have read several posts on Ricoh toner issues and used that information to check out my printer. The issue I have is that the toner auger does not turn on. When you got to force toner there is no engagement of the clutch. I have pulled the clutch and it checks out ok. I have changed the toner sensors, clear the supply tube ect.. Is it possible I have a bad board? There are no errors. The printer starts up fine.
  • Codex
    • May 2008
    • 701
    Re: Ricoh 907
    Originally posted by carr
    Hello All,
    Hello
    Have the machine light prints? Or are there any toner bank related Sc codes? (493,494,495)?.....
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
    • copier tech
      • 8144
      Re: Ricoh 907
      Hello All,
      Did you run output checks on the motor & clutch?
      • carr
        • Sep 2019
        • 5
        Re: Ricoh 907
        Originally posted by Codex
        Hello
        There are no related SC codes. The toner hopper is empty.
          • 37484
          Re: Ricoh 907
          If by the toner auger you are referring to the auger in the toner hopper on top of the development, you could have a bad toner end sensor on the hopper or a bad toner auger motor. You may also have a bad toner pump, toner pump motor or supply tube between the toner pump and the toner supply cylinder. The supply tube, once it has clogged, will need to be replaced with a new one. It has a powered Teflon coating on the inside that is easily damaged when trying to clear a clog. Once damaged, the tube will continue to clog.
          • carr
            • Sep 2019
            • 5
            Re: Ricoh 907
            Yes all is working.
