Ricoh Aficio 2075SP ~ Printing Unwanted data on Word files & Config Page
  • delosangeles
    • May 2008
    • 274
    [CQ] Ricoh Aficio 2075SP ~ Printing Unwanted data on Word files & Config Page
    Good day everyone,
    Reaching out to get opinion of the source of unwanted data when printing Word files @ page 400 of a 1000 page job. Then after a new job is sent to printer all pages are clear until once again @ about page 400 to 700 the defective printing reappears.
    I attached 3 files to have them reviewed.
    After 4500 to 5000 printed pages I printed a Printer Config Page it also appeared on their. Does not occur when doing Copy Jobs.
    I updated all firmware & even installed the BETA:
    B140_printer_BETA Firmware_v1.05B 1221 2006
    To correct Jeberish Printing, it did not correct the issue.
    Thanks for your Input
    Trade like a tiger sleep like a baby
  • FrohnB
    • Jul 2017
    • 1919
    Re: Ricoh Aficio 2075SP ~ Printing Unwanted data on Word files & Config Page
    I would suspect HDD or Memory.
    Omertà
    • delosangeles
      • May 2008
      • 274
      FrohnB, Have you see these occur in your past? , Thanks much.
      I will clear the memory & reformat the HDD for good measure,
        • 37556
        HDD or BICU
        • delosangeles
          • May 2008
          • 274
          HDD or BICU
          slimslob you too? & controller?
          I was leaning to getting into realigning the Laser Unit, OK I will follow thru.
          Thanks guys.
          • FrohnB
            • Jul 2017
            • 1919
            I have run into this before on this model and a few other models (3235C comes to mind).
            I think we have gotten lucky a couple times in just Formatting the HDD, but ultimately came the time they had to be replaced.
            If it was the laser unit, I think you would just get random lines, and not the "added text/ data".
            DO NOT DO A MEMORY CLEAR "ALL" (5-801-001). Only do it for whatever function you are trying to resolve an issue for (i.e. Scanner, or NCS). In this case, I don't think you really need to do any kind of memory clear.
            Omertà
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              • delosangeles
                • May 2008
                • 274
                That's good Knownlwdge FronhB, Thanks much!
                • delosangeles
                  • May 2008
                  • 274
                  KenB thank you, I will do that as well!
                  • rthonpm
                    • Aug 2007
                    • 2859
                    It's a memory overflow. The RAM on the machine is likely beginning to fail and can't clear itself so you get artifacts in jobs. Replacement may be difficult as this is a fifteen year old machine. Boards and electrical components that you can find will likely be used so it may be a better option to replace it with a newer machine if possible.
                    • delosangeles
                      • May 2008
                      • 274
                      rthonpm Thank you kindly for the input.
                      I have reformated the HDD as of yet but the issue has reappeared, so I am currently waiting for delivery of a new HDD from Hytech & I intend to clean the ram memory contacts & socket connecter on the print controller.
                      I will follow-up to share with everyone the out come of my efforts.
                      • Zaxxon
                        • 608
                        We are all capable of reading normally standard fonts, I guess...
                        Please start you post with brand, model, problem.
                        • rthonpm
                          • Aug 2007
                          • 2859
                          The issue isn't the hard drive, it's the memory DIMM's. Cleaning them may get you by for a time, but likely they need to be replaced.
                          • fshead
                            • 2376
                            When I use to resell laptops and had memory stick issues I would clean the contacts with
                            a pencil erasure and the alcohol..............
                            • keithxxiii
                              Just a tech
                              • Nov 2014
                              • 471
                              Must be the RAM. And also try changing the settings of your printer driver to "start printing after last page is spooled"
                              Aye! Cut the crap
