ScanRouter V2.0.4.0 Network Drives
  • jslawell
    • Jun 2025
    I have an Aficio AP3800C. ScanRouter V2.0.4.0 is installed on a Windows 2000 PC. It has been setup to save scanned documents to a network drive. I currently have 15 users setup in this fashion. When I try to set up a new destination, I no longer can see the network drives. I only see the C: drive. The current 15 users are still able to scan documents to the network drive.
    I can see the network drives from Windows Explorer.
    Any ideas?
    Thanks,
    John
  • msaeger
    • Sep 2008
    • 333
    I think you have to install it as a service not a start up folder item for the network drives to show up.
    • jslawell
      Install as a service
      Thanks for your response.
      I do have it installed as a service. It is also working for existing users. It just won't allow me to add new users.
      • Captain Scott
        • Dec 2008
        • 166
        Do you think it could be related to the account you are logging in as. Isn't there an admin account login? Just a thought may be misleading!
        • jslawell
          user rights
          the user that is logged in has admin rights to the network. I can also see the drives using windows explorer.
          • fausto1981
            IT Technician
            • Dec 2007
            • 145
            Are you sure that you have Scan Router Pro??? not the free version because the free version only allows you to scan to a local drive. If you have the Prossional edition then you shoul be able to scan to a network drive or a mapped drive.
            There is also a simple work around if all you have to do is to add one user.
            I would create a batch file that moves anything from the local drive to a mapped drive on the PC. and just create a windows task to run like every 5 minutes...
            Good Luck
            • Shadow1
              • Sep 2008
              • 1642
              You got that backwards - it has to be installed as a startup not a service in order to access network drives. SR lite will hit network drives, but not on XP - Microsoft changed the underlying access protocols SR uses in order to try forcing people into buying server software.
              73 DE W5SSJ
              • jslawell
                Run from the Startup group
                I uninstalled the program and re-installed it with the option to "run from startup" and I can now see the network drives.
                Thanks for eveyones help.
                John
                PS.
                I notied when I uninstalled it, I had the Lite version. But I can still see the network drives.
