pro c5100s Dirty background
  • Marwanalhajbi
    • Jul 2018
    • 72
    [Misc] pro c5100s Dirty background
    i have cyan dots as a dirty background i need to adjust bias,i don't how to do it on production ,by multi function sp-2-001-004 ,any one know the sp mode?
    also i have lines on printed page comes from development unit,it keeps changes it's position,any ideas how to fix that?
    thanks alot
    • 37449
    Re: pro c5100s Dirty background
    The best solution to drum spots is to replace the drum. What are your current PM counters?
    Sounds like you have developed a stiction problem. Most likely from using after market toner.In that case you will need to purge the toner supply system, replace the developer, clean all waste toner from the PCU and use only Genuine Ricoh toner and developer. If it does not say Genuine Ricoh on the box, it is not.
      • 23006
      For us guys that haven't seen Ricoh in a while please explain "striction". =^..^=
        • 37449
        It is a condition where the toner would tend to stick to the drum surface and not be removed by the cleaning blade. Common the 50 to 80 models depending on which blade was used.
          • 23006
          We see that on a lot of the Toshiba organic photoconductors. In the Toshiba classes they explain that there's a clear coating on the drum that prevents the toner from sticking, but that coating wears off/wears out, then toner starts to adhere. It's usually a ring of teardrop shapes around the drum, that leave a void where image is not developed. Similar? =^..^=
          • eccelobo
            • 113
            thanks alot
            SP 2001-004 is the adjust for grid bias, but this machine does not have a grid plate since it uses a charge roller. Maybe you meant SP2201-004...
            Anyway, in the Pro C5100s there is SP2201:
            [Set DC Charge]
            Sets DC Bias Charge. However, only enabled when [0:FIXED] is selected in
            SP3-600-001 ProCon Potential Control.
            001 K
            002 C
            003 M
            004 Y
            [300 to 1000 / 550 / 1-V/step]
            and SP2212:
            [Set Dev DC]
            Sets Development DC Bias Charge. However, only enabled when [0:FIXED] is
            selected in SP3-600-001 ProCon Potential Control.
            001 K
            002 C
            003 M
            004 Y
            [200 to 800 / 450 / 1-V/step]
            Good Luck!
            • davel
              • Oct 2011
              • 1101
              Do not f*** with bias, replace parts that are due with genuine parts.
                • 37449
                [Set DC Charge]
                001 K
                002 C
                003 M
                004 Y
                and SP2212:
                [Set Dev DC]
                001 K
                002 C
                003 M
                004 Y
                Good Luck!
                Incorrect, older models like the B220 used charge rollers and still had SP 2004 settings. In fact I think the the B220 was,released in about 2005 was the last model to have it. It caused more problems than it cured
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Can you please print a PM counter list and scan it on here, that will give us a better indication of what is wrong with it.
                  Hit it.
                  • eccelobo
                    • 113
                    B220 has B051 2160: Charge Corona Assembly, and indeed G070 2156: Charge Corona Grid.
                      • 37449
                      Sorry, typo. It should have been B202 series. Also B190 series.
                      • Marwanalhajbi
                        • Jul 2018
                        • 72
                        it''s used machine and i replaced all unites inside including pcu,no results,i think there some how a sp mode can help due to it already has been changed before
                        • bat
                          • Sep 2008
                          • 140
                          You can try this.
                          Ch-C1Pro Troubleshooting Dirty Background.pdf
