DSm415pf Error message 36851 network scanning using VISTA
  • 3bok3bok68
    Senior MFP Technician
    • Nov 2008
    • 56
    When I try to network scan using VISTA, an error message saying "36851" No response from the scanner appears"anyone can help to solve this problem
  • YHEL23
    • Nov 2008
    • 146
    Hi friend,
    Try off 1st your firewall.....i have problem before after off the firewall, i can scan....good luck bro.....I'm a pinoy also base in brunei..
    DYNAMIC OFFICE SOLUTIONS
    • 3bok3bok68
      • Nov 2008
      • 56
      Thanks Bro I try that...also Im pinoy base in Saudi Arabia...you know Jerry Ogimas?Good luck bro.God bless you.
      Originally posted by YHEL23
      Hi friend,
      • YHEL23
        • Nov 2008
        • 146
        Hi Bro.,
        Yap i know him but his in dubai now....if you want to contact him this his # +971509202306.God Bless to Bro...
        Yhel
        • 3bok3bok68
          • Nov 2008
          • 56
          Thanks bro for your information about him...God Bless you too....
          Hi Bro.,
          Yhel
          • YHEL23
            • Nov 2008
            • 146
            Hi Bro,
            What driver did you install?i I understand that they have two type of driver.XP and vista. Printer is it no problem?
            • 3bok3bok68
              • Nov 2008
              • 56
              Hi Yhel,
              Twain Driver Bro...I installed the latest version of twain driver.
              Hi Bro,
              • Betong
                • 16
                hi! try to disable windows firewall and also the any anti-virus personal firewall, if it works one of the firewall is blocking the scanner software. cheers...
                • Llama God
                  • Mar 2009
                  • 1353
                  Have you tried removing the Twain driver and scanning to folder via SMB? Sure as eggs is eggs that'll fix your problem!
                  • Vulkor
                    • Jun 2009
                    • 946
                    Aficio 1515/1515MF/1515F Savin - 35153/515MF/3515F Gestetner DSm415/DSm415pf/DSm415f Lanier LD015/LD015f/LD015spf
                    I am pretty sure you will not be able to SCAN to folder with SMB.
                    These machine was before Vista and there is no firmware update to fix the issue.
                    • Llama God
                      • Mar 2009
                      • 1353
                      You may be right, I don't recall linking one of these to anything but XP or Server 2003.
                      • slot
                        • Jul 2008
                        • 341
                        If you are twain scanning try adding TCP port1022 into the exceptions to open up the port this may help
                        • Llama God
                          • Mar 2009
                          • 1353
                          Enjoying the weather Slot?!!
                          • slot
                            • Jul 2008
                            • 341
                            Hi Llama God the weather here in Kent is not too bad in the Ashford area its a pain in the rear when operation stack is on. this Seems to be happening about every 2 weeks you dont often see it on the news but this area becomes one big lorry park makes the job very hard some days
                            • Joshua Herrero
                              Re: DSm415pf Error message 36851 network scanning using VISTA
                              PLSSSS HEEELPPPP.. where can i download gestetner dsm415f drivers? or software? plsss badly need it.. or can anybody help me how to connect this machine into a computer? pls help.. tnxx
